928 Forum 1978-1995
Sponsored by: 928 Specialists
Vacuum line ? and direction ?
Old Oct 5, 2008 | 06:45 PM
Tampa 928s's Avatar
Tampa 928s
Default Vacuum line ? and direction ?
I have replaced the power booster and found a red vacuum line has nothing to connect to any idea where it goes?
The Air control valve on the stabilizer bar shows an arrow for correct placement; which way does it go "arrow toward intake or opposite way.
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
Old Oct 5, 2008 | 06:48 PM
SeanR's Avatar
SeanR
If you've got main vac off the intake, you can cap off that 4th connection. This being if you have a 5 speed.
I might be wrong, it's happened before.
Old Oct 5, 2008 | 07:24 PM
Tampa 928s's Avatar
Tampa 928s
It is a 5-Speed
Found out where the red vacuum hose goes, it went to the main BP hose on the bottom.
Still don't know which way to position the air valve.
Old Oct 5, 2008 | 08:10 PM
SeanR's Avatar
SeanR
Are you talking about the blue check valve?
I can't explain stuff worth a crap today...................I had a nice long explanation wrote out but when I re read it, it made no sense.
That valve holds vacuum to the main vac tank, it tee's off from the brake booster.
I'm thinking I should not have posted.........damnit.......lol
Old Oct 6, 2008 | 12:06 AM
Mrmerlin's Avatar
Mrmerlin
Team Owner
Sean dont be so hard on yourself ,you got a brain and a heart, thats good enough.............. Stan
Old Oct 6, 2008 | 12:12 AM
Fabio421's Avatar
Fabio421
Man of many SIGs
He's talking about the valve thats mounted on the cross brace that allows unmetered air to leak by to raise the idle when the A/C is in use.
Mark, the arrow shows whick way you should hook it up, meaning thats the way the air flows. The arrow points to the hose that goes to the TB.
