Will removing this bolt mess up my alignment?
I removed this bolt (and the one on the other side) to lube with silicone to stop a sqeak (it worked). However, did I mess up my alignment by doing this? It didn't occur to me until afterwards that this was a possibility.
H2
H2
I got to wondering since the lower shock pivot pin is threaded on both ends and when snubbed back into place, the pin had shifted more forward than when I started. If it has no bearing, that's great news since I really don't want to drive 125 miles to the nearest mechanic who knows how to realign a 928. Hartmut in Hayden Lake, ID. Porsche trained mechanic. I sure hope he never retires.
Thanks, guys.
H2
Thanks, guys.
H2
Team Owner
if you can loosen one of the nuts try to trun the pin with the other nut and watch to see if any of the part it goes through are moving sidways, if they are then you have a bent pin, it should be replaced a used one will work
Thanks, guys.
H2
Thanks, guys.
H2
