removal and preservation of fuel pump
One think along those lines that just occurred to me is the last two times I restarted the car after having the battery disconnected the car acted like it wouldn't idle at all. I had to pump the gas pedal until it warmed up...once I drove it around the block a while it went into the high idle and surging mode again! subsequent restarts with the battery connected don't give that no idle at start up situation.
Maybe that would be a symptom one of you could recognize that will point me toward the culprit.
now I'm thinking its the LH brain.
When the battery is disconnected the brain looses its memory and when reconnected takes some time of engine running to adapt. Can you try the brain in another car?
I probably will have to try to get one of John Speakes vendors to let me buy one with the contingency that if it turns out I didn't need it I can exchange it for credit on a new MAF...I think they would do that...maybe buy the MAF first then try the LH since the LH costs more.
That's why I'm trying to eliminate any other possibilities first. As much as I'd like to have a spare MAF or LH I really don't want to invest in one right now. If it is needed to fix the car then sure I'll buy one but I need to stop the financial bleeding on this project sometime soon!
Craig, your avatar name certainly seems appropriate on this deal. With no other guinea pig Sharks around, you might want to mail things like your LH and/or MAF to one of us for an "other car" test.
I'd be happy to help on that, as I'm sure others would as well.
I'd love to try the spare MAF. Let me get the car back on the road today with the new fuel pump, filter and relays and if that doesn't fix things I'll send you a PM with my info and of course I'll pay for the shipping and take responsibility for the MAF if anything happens I'll replace it.
