928 Forum 1978-1995
Sponsored by: 928 Specialists
SBC swap PROS and CONS....Who bought the renegade mounts and kit...?
Old 09-21-2008, 12:54 AM
SeanR
SeanR's Avatar
I think my computer is blowing around a .10 right now.
Old 09-21-2008, 12:58 AM
Jack Riffle
Jack Riffle's Avatar
Haven't heard from Hacker tonight....what am I thinkin His is probably too trashed to boot up
Old 09-21-2008, 01:00 AM
Leslie 928 S2
Leslie 928 S2's Avatar
LOL....too true. Mine's only blowin' about a .03 so far. But I'm workin' on it!!
Old 09-21-2008, 01:03 AM
Jack Riffle
............Rookie
Old 09-21-2008, 01:14 AM
Leslie 928 S2
Hey! Who ya callin' rookie???
I only got started an hour ago!!
But it was definitely nice of schmuckrider to give us something fun for us to talk about!!
Guess he lost his ball.............
bearings, now.
Old 09-21-2008, 01:39 AM
devilinblack
devilinblack's Avatar
After working on my interior all afternoon I just had to walk down to the store to restock on beer. Can't seem to be productive on the car without the magic elixir!
As for bore and stroke... I haven't had enough yet to go there.
Old 09-21-2008, 01:42 AM
Leslie 928 S2
Right! So, I guess we'll be hearing from you in about an hour then, right?
Old 09-21-2008, 02:17 AM
aggravation
aggravation's Avatar
You guys and gals should be right at home at our local biker bar named after the combustion engine, The Suck Bang Blow
Old 09-21-2008, 09:05 AM
Vilhuer
Vilhuer's Avatar
Boring numbers:
Factory options
Bore / Stroke = Displacement CC / CI
95.00 / 78.90 = 4474 / 273 = 4.5L stock size
95.50 / 78.90 = 4521 / 276 = 4.5L 1st oversize
96.00 / 78.90 = 4531 / 276 = 4.5L 2nd oversize
97.00 / 78.90 = 4664 / 285 = 4.7L stock size
97.50 / 78.90 = 4713 / 287 = 4.7L 1st oversize
100.00 / 78.90 = 4957 / 302 = 5.0L stock size
100.50 / 78.90 = 5007 / 305 = 5.0L 1st oversize
100.00 / 85.90 = 5397 / 329 = 5.4L stock size
100.50 / 85.90 = 5451 / 333 = 5.4L 1st oversize
944S2 or 968 piston + stock crank
- Block needs to be specifically selected 5.0 or 5.4 as many do not have enough material from more than 103mm bore. 4.5 or 4.7 do not have enough material for much more than 100mm bore.
- Rods needs to be custom parts to get piston to block level at TDC.
104.00 / 78.90 = 5362 / 327 = '78-91 crank + stock size
104.50 / 78.90 = 5414 / 330 = '78-91 crank + 1st oversize
104.00 / 85.90 = 5838 / 356 = GTS crank + stock size
104.50 / 85.90 = 5894 / 360 = GTS crank + 1st oversize
Common 95.25mm (3.75") stroker crank
- All but 968 pistons will very likely require skirt modification to fit in at BDC, earlier the piston more skirt needs to be lifted.
95.00 / 95.25 = 5401 / 329 = 4.5L piston stock size
95.50 / 95.25 = 5458 / 333 = 4.5L piston 1st oversize
96.00 / 95.25 = 5470 / 334 = 4.5L piston 2nd oversize
97.00 / 95.25 = 5631 / 343 = 4.7L piston stock size
97.50 / 95.25 = 5689 / 347 = 4.7L piston 1st oversize
100.00 / 95.25 = 5985 / 365 = 5.0 or 5.4L piston stock size
100.50 / 95.25 = 6045 / 369 = 5.0 or 5.4L piston 1st oversize
104.00 / 95.25 = 6573 / 395 = 944S2 or 968 piston stock size
104.50 / 95.25 = 6535 / 399 = 944S2 or 968 piston 1st oversize
There are obviously other more rare options like custom size pistons for Alusil block, Nicasil coating or steel liners etc. Answer to question who has 6L piston kit is no one really as there are no 105.5mm (GTS crank) or 110mm ('78-91 crank) pistons available. Since only way to make it work would be to use wet steel liners and there aren't any kits available like that.
Old 09-21-2008, 10:46 AM
928 Is My Favorite Time of Day
928 Is My Favorite Time of Day's Avatar
Vilhuer- Excellent post. Thanks for the information!
Joe
Old 09-21-2008, 03:34 PM
IcemanG17
IcemanG17's Avatar
Erkka summed it up perfectly....
basically the easiest way to increase displacement is with a stroker crank & overbore pistons...all depending on what you plan to do with the car......there are many 6.4-6.5L strokers out there with the 95.25mm crank and 104-104.5 pistons that make A LOT of power.....some close to 600whp
Old 09-21-2008, 07:31 PM
surfridermason
surfridermason's Avatar
Location: Philadelphia, PA , USA The Great Fighting City of Brotherly Love
Originally Posted by Leslie 928 S2
I don't believe I just said that.
The Guy made me do it....it's all his fault!
LOL. I want to do it.... It's just sitting on the shelf at the moment as a remote possibility....
Old 09-21-2008, 07:33 PM
surfridermason
[QUOTE=Vilhuer;5828260]Boring numbers:
THANK YOU! HOLY COW>
Old 09-21-2008, 07:34 PM
surfridermason
WHO HAS THE BEST VALUE IN THIS PACKAGE>>> THIS IS WHAT I WANT TO SEE/// Cost needs to be terrestrial.
Old 09-21-2008, 07:36 PM
Leslie 928 S2
Come on! You gotta do it! You said you would!
I really want to see that....that has to be sick.
Then come to track day and have some fun with us!
(Sorry about last night man...had a few too many here...it's a clear and present danger tonight too. lol)
Quick Reply: SBC swap PROS and CONS....Who bought the renegade mounts and kit...?
