The pod lights are always on bright - they go on low when the lights are on... the low is variable based on the dimmer - if the dimmer is out (or if there are any other problems with that circuit) the pod lights will simply go out when the lights go on... as in your case.
I sprayed some WD40 on my S4's dimmer wheel and rolled it back and forth several times. Some pieces of corrosion fell out and the switch has worked perfectly ever since.
I had the same exact problem with my '89. Turned out the PO had used a headlight relay from an earlier car. When I replaced it with the correct part, it worked fine.
Eh what....?
I can guarantee the headlight relay has absolutely nothing to do with this issue... (don't go there). The pod lights are related to the marker lights - nothing else.
