At the local store any other car with same front hood shocks
Ive seen a post about purschasing the front hood shocks Does any other car use the same hood shocks so I can buy them local
Basic Sponsor
Why bother when we sell them for $12 each 8>)
Roger
Roger
Make sure you orient them the correct way when installing; they last much longer that way.
And yes, buy them from Roger and support the 928 folks.
Team Owner
if your hatch shocks are worn out they can usually be used on the hood, (caveat if it takes a bit more force to close the hood then you have hatch shocks on , IE you cant close the hood half way and it will stay there) IIRC the hood shocks supply about 35 pounds and the hatch shocks supply about 100 pounds. in other words if you can`t press the hood shock to close with one hand and the other end of the shock against the ground then you probably have a hatch shock these take 2 hand to hold
Team Owner
I have seen 928s fitted with hatch shocks on the hood ,there is usually a bulge just past midway on the hood and when the safety catch is released the hood flys up, its also a good way remove the shock locating *****, if you dont have the correct shocks then leave them off.
I took a set off of a a car at a car show as the owner was wondering why his hood was always slamming into the up position when he released the safety catch. I removed them and told him to save these for the hatch and get some hood shocks
