928 Forum 1978-1995
Sponsored by: 928 Specialists
My own RMB (Sort of)
Old 08-30-2008, 06:50 PM
LightStriker
LightStriker's Avatar
Default My own RMB (Sort of)
Ok... Not really a RMB. More like a series of pipes.
When I got the car, and up to now, the rear muffler was missing. Which was leading to horribly annoying problem...
1) The engine sound was bouncing inside the hull. Making it horribly noisy inside.
2) The smoke was getting caught under the car... And always manage to find it's way inside. Which was potentialy dangerous to drive with the windows up!
3) Was also horribly ugly... As the smoke was coming out of under the car all around it. Was like if the car was on fire...
RMB are a bit expensive... Well not really, but I don't have plenty of cash.
Also, I only found dual exhaust tip... Which I don't like that much. Finally, it's a 16v... so no dual system.
Before :
After :
Bendable pipe :
Attach :
How it look outside :
And to test my new photo camera, which also take video :
(BTW, LOVE the sound. Sound mean!)
Total Price : 110$CAN
Time : ~1h
Old 08-30-2008, 07:37 PM
djurek
djurek's Avatar
Looks geat. How about a pic from further back? So we can see the whole thing.
Old 08-30-2008, 07:48 PM
LightStriker
The video on YouTube is taken from a bit more away...
But who am I to deny taking picture of something I love.
It's maybe not totally centered... But with the bendable pipe I got some space to move it a bit.
Old 08-30-2008, 09:53 PM
pcar928fan
pcar928fan's Avatar
Not bad...nothing wrong w/ that...
Old 08-30-2008, 10:14 PM
F451
F451's Avatar
Good job. Sounds great too.
And I love the color of your 928.
Ed
Old 08-31-2008, 03:21 AM
rawky
rawky's Avatar
could you use bendable pipe, wouldn't it melt w/ heat?
Old 08-31-2008, 11:00 AM
Angel84-928
Angel84-928's Avatar
I like it !! I'm always up for an inexpensive alternative.
I'd like to hear it when you rev it up.
Parts list, plz.
Old 08-31-2008, 12:39 PM
Shark Attack
Shark Attack's Avatar
I like the double tip better. But for a DIY project. Great job and if on a budget I'd live with it!
Old 08-31-2008, 01:05 PM
LightStriker
Well, it's made to go on an exhaust line. It's a really resistant pipe, quite hard to cut it, but it's also completly flexible.
As for the parts list :
- Ractive Oval Stainless Chromed Exhaust Tipe : 49,99$
- 2 Feet Flexible Exhaust Pipe : 13,49$
- Stainless Muffler Support : 34,49$
- Tube of Exhaust Cement : 3,99$
- 6" of Exhaust Joint Tube for 2" 1/4 : 4,99$
All found at Canadian Tire.
There was double tips parts... It was just a preference choice. So someone could easily replace the Ractive tips for a double one. I think Ractive also make some.
Double Tips : http://www.canadiantire.ca/browse/pr...08474396672477
Old 08-31-2008, 01:46 PM
SeanR
SeanR's Avatar
Looks really nice.
Old 09-01-2008, 09:22 PM
Imo000
Captain Obvious
Super User
Imo000's Avatar
Like the tip. Did you weld any of the connections or is it all only muffler cement?
Old 09-01-2008, 09:59 PM
LightStriker
I don't have any welding equipment... But I should get some. One day. I'm actually not bad with welding.
The tips has it's own connection to hold the pipe... So there is no cement there. Only at the 6" joint. And so far it seams to hold correctly. The text on the tube of cement says the longer I drive, the hotter the exhaust get, the stronger the paste become. Seams to work nicely so far.
Old 09-01-2008, 10:48 PM
Mongo
Official Bay Area Patriot
Fuse 24 Assassin
Mongo's Avatar
There were 308 Ferrari guys in a forum that I was subscribed to that did the same thing. Autozone/Kragen Special with a fancy tip. Nothing wrong with it. Sounds amazing I'm sure!
Old 09-01-2008, 11:45 PM
tailpipe
tailpipe's Avatar
i had the same problem except i took off the flange brought it down to the muffler shop with a piece of brake line i bent to the shape and length i wanted they bent the pipe and welded on the flang for like 40 bucks except i didn't get the fancy tip with mine i just cut the pipe on an angle after i mounted it sounded great then the middle muffler rotted out so back to the mufler shop i went i took the whole pipe from the muffler back this time they bent me the whole pipe all 7 feet by 2.5 inch for 60 bucks my friend and i welded the flange and hangers on ourselves now that exhaust sounds really awsome but it is a tad loud all my muscle car friends think i put a 350 in the thing how rude they are
you took the next step putting that tip on that looks awsome i will have to see what i can find to put on mine here great DIY fix
Old 09-02-2008, 11:24 AM
Imo000
Captain Obvious
Super User
Imo000's Avatar
I’ve used muffler cement before on small leaks but never as a structural connector. That stuff when fully cured is almost like dried clay and it isn’t really that strong. Keep a close eye on it cause I don’t think it will hold up. If you find it that the cement let go. Just go to the closest muffler shop and they can tack it on for you in 5 min ($15). I appreciate your effort and dedication to do this at home but a muffler shop could have made a proper tail pipe (using your tip) for less than what you paid at Canadian Tire.
Quick Reply: My own RMB (Sort of)
