Brake Fluid Flush Procedure w/Pics
#46
Chronic Tool Dropper
Are you able to build any pressure with the bleeder pump? That's about the only reason I can think of, unless you've replaced the MC and/or adjusted the pedal hight to the point where the MC piston cups are blocking the reservoir ports.
