Paint On Intake
Team Owner
what flaked off isnt paint its a powder coating. to do it right will require removal of the intake and a complete stripping (media blasting) of the intake then a wash and bake, to out gas the metal then a new application of powder coat.
Others have tried painting and that also seems to work OK but you should test the paint to see if fuel or other solvents will remove it. If you were going to use paint then i would suggest some kind of epoxy paint
But I've used an abrasive cream, and the inatake has come out a beigey colour, not the bright silver shine I'm used to....Why?
edit: Think I wasnt to use it on the intake , But it looks fine, doesn't bother me in the slightest...
The intake on my 90 GT was chunking off big time and the inside was all caked up with gook. Had it sand blasted inside and out for $75. Then had it powder coated silver chrome for $80. This was several years ago. I did the lettering with Testors Enamel.
Sold the car before I got around to doing the cam covers.
It is not powder coated it is painted and it is done in Zermatt Silver.
It is also magnesium and if you expect the job to last you will need to grit blast it with a slag product like Black Beauty and then use a dichromate pickle to prepare the surface for paint. Otherwise it will not last as long as you would like.
Magnesium is a relatively durable material assuming it is not allowed to be impacted by the elements directly. That is why a good coating is critical. Coal slag is a good medium to use since it disintegrates on impact although it does remove a few thousandths of material. Unless the casting suffers from corrosion or microshrinkage you should be fine.
Yea, I always think about what Sterling went through due to this same thing! TERRIBLE! Of course it led to a decade long odyssey of building the monster motor he now has! So I guess that is the bright side...it pushed the envelope on 928 development! Thanks G-man!
Rennlist Site Sponsor
I was in a hurry to get to SITM...
The finish on my 90 GT intake and cam covers was flaking badly. I had to pull the intake anyway, but didn't have the two weeks for bead blasting and powder coating. The finish scraped off very quickly and easily, leaving the gray factory coating undamaged. A quick scrub with abrasive pads and solvent, three cans of silver wheel paint, and the intake and cam covers looked pretty good. The intake was off the car, the cam covers were finished in place.
