New Product: Solid Vacuum Tubing Now Available
Developer
I now carry replacement solid vacuum tubing for the 928 and others. We were surprised how many hardlines had become brittle and how easy they were to snap or crack.
Here you go:
Description: Perfect replacement for the OEM solid vacuum lines that become brittle with age and often snap when moved. These vacuum lines are opaque black nylon, and UV and chemical resistant. They have a minimum bend radius of 1.5" without collapsing!
Two Sizes Used: Porsche used two different sizes of solid vacuum lines on these cars. We provide 8 feet of both!
Note: Each kit includes two 8' lengths of both 4mm and 3mm new black nylon vacuum line, which is enough to do an entire 928, 944, 951 engine bay. Rear-engined cars (914, 911, etc) may need 2 kits if re-lining their entire car.
The complete listing is here:
http://www.928motorsports.com/parts/...cuum_lines.php
Here you go:
Owns the Streets
Needs Camber
Needs Camber
We deal in partial vacuum and if nothing flows then there is no potential for work /movement .....so something has to be moving flowing or the tubes might as well be "solid" as opposed to hard.
Developer
If it is "solid" how does it flow ??
What's the difference between those and silicone vacuum hose?
Many cars have sections of both. Generally speaking, from 85 and up there is much more of this stuff - nylon tube running the length of the circuit, and small sections of hose making the actual connection.
All years (even early cars) use this stuff under the dash for the HVAC controls. That tubing even after 25+ years is usually still flewxible and not brittle. But the under-hood sections become brittle owing to the heat of the engine bay.
Developer
Different. The silicone hose replaces the hose you have. This is the ny;lon tubing to replace the tubing you have. (although, you can replace some tubing with hose if you like)
A vacuum is any pressure between atmospheric pressure and absolute zero pressure, in this instant.
A vacuum is created when the pressure within a "system" is reduced below the atmosheric pressure when the gas is partially removed. A "vacuum" cannot flow, the gas, "air" in this instance in the vacuum system of the HVAC, is removed by the air induction system of the engine on the inlet stroke in each cylinder acting as a vacuum pump.
Vacuum hose is usually some form of reinforced side wall, so that the hose will not collapse when a vacuum is induced due to the atmospheric air pressure being greater than the pressure within the hose.
A "solid" side wall thickness of a pipe or hose will prevent collapse where as some plastic or silicone hose will tend to collapse when the vacuum or pressure within the hose approaches absolute zero pressure. It is all a matter of differential pressure- so endith the reading.
Tails 1990 928S4 Auto
Ok so what we have here is solid wall semi-ridged hollow tubing designed to contain a partial vacuum and make all kinds of things like Auto transmissions , flappy valves , ignition timing , heater valves , cruise control , door locks , dash flaps , fuel vapor recovery , power brakes ; have a chance to work as they were intended. Since we are dealing with changing levels of partial vacuum there is flow ! And Carl just thought he was selling some plastic tube....
