Power Window Problem What to Check Next
Just back from a nice little drive. Had the driver window down.
Got home and window will not go up. Checked the passenger side window and no go either. Checked and replaced fuse #21 for powerwindows. Old one looked fine, but changed anyway.
Where should I go from here?
TIA
TIA
You know I was looking at the relay chart for MY and could not find a relay for the Power Windows. I guess I should have looked closer. Relay # VI is Window Winder????? I'll check it out.
Yep - window winder. IIRC the relay is specific to the windows and sunroof and cost a few dollars more than the common relay for the fuel pump, horn, etc.
Team Owner
open the relay and clean ther contacts, it might be a temporary fix
