928 Forum 1978-1995
Sponsored by: 928 Specialists
Unpredictable Engine Shutdown
Old Jul 28, 2008 | 03:15 PM
Skunkworks's Avatar
Skunkworks
Default Unpredictable Engine Shutdown
Background: 1982 928 w/ AT
The car drives well, except that the engine shuts off while driving (unpredictably). Subsequently, the engine will not start for a period of time (15 min - 90 minues). Then, voila! The engine starts and away I go -- sometimes for 30 miles other times about a half a mile. She always starts cold.
I've been through the fuel system, dropped the tank, replaced the tank filter, fuel filter, new fuel pump. Installed a temporary fuel pressure gauge and there is good pressure (even after the engine stops).
I've replaced the coil and the ignition switch (really needed it). Immediately after an "episode", I hooked a timing light and determined spark on the leads (inductively).
I really love the way the car drives, I just can't trust it.
Any help is appreciated.
David
Old Jul 28, 2008 | 03:16 PM
Jim bailey - 928 International's Avatar
Relay relay relay !!!!
Old Jul 28, 2008 | 03:23 PM
AO's Avatar
AO
Supercharged
What Jim said.
Old Jul 28, 2008 | 03:24 PM
Bill51sdr's Avatar
Bill51sdr
Fleet of Foot
That was entirely predictable .
Old Jul 28, 2008 | 03:25 PM
Skunkworks's Avatar
Skunkworks
I failed to mention that I have also replaced the fuel pump relay.
If a relay, can you provide a list of the "usual suspects"? Is there a procedure to test the relays?
Old Jul 28, 2008 | 03:41 PM
Fuel injection relay is most likely ...928 615 119 00 ....top row eight from the left...we have them
Old Aug 2, 2008 | 12:50 AM
Chris Hansen's Avatar
Chris Hansen
I had some similar symptoms, and it turned out to be the (dreaded) green wire.
Old Aug 2, 2008 | 09:14 AM
toofast928's Avatar
toofast928
David,
Inspect all your vaccum hoses. Or better yet just replace all of them.
I had the same shut down issue and discovered the vaccum hose to the A/C idle motor had deteriated inside out, causing a vaccum leak when the hose became hot, sealing the vaccum leak when the hose cooled off.
