928 Forum 1978-1995
Sponsored by: 928 Specialists
replacement interior light
Old Jul 18, 2008 | 08:08 AM
Dave H.'s Avatar
Dave H.
From: Seattle - it's not Hell, but you can see it from here!
the black lights are from the 20th anniversary and/or R32 GTI...
p/n for the connectors:
housing (3 pin) - 893 971 633
wires - 000 979 225
Old Jul 18, 2008 | 12:27 PM
AO's Avatar
AO
Supercharged
Originally Posted by Alan
directly fits exactly in all locations except the rear hatch one at the rear - this one needs some shortening of the socket end for clearance inside the hatch. The wiring uses a different connector so needs to be adapted.
Here is a picture with a connector (no wires) installed and also of how I adapted for the rear hatch location (soldered & pigtail ends JB Weld encapsulated.
Alan
Alan... What LED bulb is that? I was looking for one to fit, and couldn't find one that fit well. THe one I have in there sorta fits, but doesn't give off much light.
Old Jul 18, 2008 | 12:36 PM
Alan's Avatar
Alan
Electron Wrangler
Andrew Its a 44mm 10 LED bulb. they don't fit without modification - here is the old thread on that:
https://rennlist.com/forums/showthre...eferrerid=6055
Alan
Old Jul 18, 2008 | 12:42 PM
AO's Avatar
AO
Supercharged
Thanks. I had completely forgotten about that.
Old Jul 18, 2008 | 12:52 PM
John Veninger's Avatar
John Veninger
Thanks again everyone!
Old Jul 18, 2008 | 01:06 PM
John Veninger
Maybe one of our 928 vendors would like to carry the black ones.... hint hint.....
Old Jul 18, 2008 | 01:19 PM
heinrich's Avatar
heinrich
928 Collector
3B0-947-291-B-B41 is the part number
Old Jul 18, 2008 | 05:45 PM
6.0-928S's Avatar
6.0-928S
Thanks H. Is that for the grey one or black one?
Hammer
7 Porsche Models That Have Aged Like Fine Wine
Old Jul 18, 2008 | 07:27 PM
ROG100's Avatar
ROG100
Basic Sponsor
I have them in Black and Grey for $36 each.
New VW stock.
Also available in Tan - would have to order those.
Old Jul 18, 2008 | 08:38 PM
heinrich's Avatar
heinrich
928 Collector
Hammer
Black one Brother. Roger ... :applause:
Old Jul 27, 2008 | 01:37 PM
Skiviking's Avatar
Skiviking
Alan, I got my VW int light like your from my local auto yard @$5 each. I have one question on the wiring up of these. What color wires from the orig int lights went to what color wires for the Passat Int lights. If you could help me there I'd appreciate your help very much.
Alan
Old Jul 27, 2008 | 01:55 PM
Alan's Avatar
Alan
Electron Wrangler
Actually since I didn't use a VW harness - I don't even know what colors they use. However its easy to tell... take the bulb out and use a multimeter to test the connections: The Porsche red wire should go to the direct connection to one end of the bulb (unaffected by the switch). The Brown/White wire goes to the terminal that connects to the other bulb terminal only when the lens is in the middle (door switched) position. The brown wire goes to the terminal that connects to that same bulb terminal only when the lens is in the permanently on position.
Roger - Great news on stocking these - I may just springs for some black ones...
Alan
Old Jul 27, 2008 | 02:21 PM
Skiviking's Avatar
Skiviking
Alan,
Thanks for such a quick response. I will go the way you suggest though I have never used a multi meter before so this will be interesting to say the least.
If I get my camera back I will post the before and after photo's as I will be redoing the color Black as the auto yards were beige. But I must say I like these better than the 928's originals just in looks and a sturdier housing too.
Many thanks!!!
Alan
Old Mar 10, 2009 | 10:34 PM
byrdman454's Avatar
byrdman454
I know these lights have been used for the two in the headliner and one in the hatch. Can these also be used in the doors? I would rather have all 5 lights the same style.
Old Mar 10, 2009 | 10:42 PM
heinrich's Avatar
heinrich
928 Collector
yes
Slideshow: Some Porsches have become icons with age, proving that great design doesn't follow trends or expiration dates.
By Verdad Gallardo | 2026-06-16 13:40:23
