Hi all
Is there an easy or simpler way to bleed my clutch? This is a job I have never done on any car at all ever so details would be good.
Cheers
Mike
I replaced the slave recently, and bled the system without a pressure bleeder, but with an assistant to operate the clutch pedal by hand. I was under the car bleeding using the nipple on the slave. The only preparation was depressing the slave piston fully a few times first. My assistant (girlfriend) had already helped me bleed the brakes so time was limited - but the whole process took less than twenty minutes. One of the least difficult jobs I have done.
