928/1989 Brakes Jamming
Is it just one caliper or all four?
All four would tend to make me think it is a bad master cylinder. Put new brake fluid in the system first, if the problem continues, replace the master cylinder.
If it's just one wheel locking up, then I would rebuild the bad caliper and bleed the system.
Fleet of Foot
if you find a caliper sticking ( IE by doing the test the rotor with the IR gun ) make sure to rebuild both calipers for that axle. Make sure the push rod is adjusted correctly as if its not retracting then the master will hold pressure i9n the lines then its only a matter of time till thiungs get hot.
So what was the last thing that you fixed???
