Need Radiator help fast!
My 89 radiator failed this weekend and I have removed it. Looks like a loss at this point. I have a good radiator out of my 82 I would like to swap out. Both are automatics. The 82 looks like its was a later replacement. The 82 has no in radiator oil cooler lines even though the Radiator has the oil cooler on the driver side. ( it is capped off at present)
Does anyone know if I would have a problem swapping these out? The PET manual shows a different part number for a 82 and a 89 but like I said ...this may be a later replacement.
Basic Sponsor
Dean,
You should be good to go with no problem.
What is the part number of the one in the 82 and I will check it out for you.
Part number should be a green sticker on the bottom.
Roger
Roger
![](https://cdn.shopify.com/s/files/1/1694/8685/files/928sRus_rennlist.png?v=1621798567)
Does it have the "Do It Yourself" manual transmission, or the superior "Fully Equipped by Porsche" Automatic Transmission?
George Layton March 2014
928 Owners are ".....a secret sect of quietly assured Porsche pragmatists who in near anonymity appreciate the prodigious, easy going prowess of the 928."![thumbsup](https://rennlist.com/forums/graemlins/bigok.gif)
Hi Roger,
The part number is 928-106-040-02. I checked the PET and that is the correct rad for the 82 even though the rad looks much newer and the green part number sticker is in VERY NICE shape....no grime. The only visual difference I see in the 2 is the 82 model side tanks have a lip that holds the bottom fan shroud on where as the 89 rad has no lip...the shroud is one pc. Other than that they LOOK and measure the same.
I just want to be SURE.....If theres a chance this will cause problems I will bite the bullet and order a replacement.
different radiator lacks the attachment points for the later fan schroud... Only our alloy radiator has the dual fit attachments for BOTH 78-86 AND 87 >
Basic Sponsor
Jim,
Can you elaborate further please - what are the later attachement points?
Arn't they the ones that you chop of the alloy rad to allow fitment of the later shroud?
Roger
Roger
My early fan shroud attached at the bottom with 2 ties through 2 holes in the shroud and rad.....the new lower fan shroud has 2 tabs that slide in 2 slots in the newer rad. The top looks like they both attach the same.....Is that the only difference???? If so I am sure I can make this work.
Done With Sidepatch
