Need Radiator help fast!
STILL waiting on the radiator shop! I hope to reinstall this weekend. Brian...you are always welcome in my garage. Headed to Knoxville soon?
Probably over the 4th. I am trying to talk my wife into taking Wednesday off and leaving early so I will have more time with my car (sad, I know). If she does, then I will be coming up in the 928 Sat for the day only. Mechanically she is right on, I am still working on my frozen sunroof and trying to find someone local to vacum down my crappy AC. I found 1 shop that will do it but they work when they want and it is far enough away that it would be a PITA to do it when I am supposed to be on the job myself.
The inlaws only live about ten minutes away from you at the other end of Lovel. I will call you when I am up there.
![rockon](https://rennlist.com/forums/graemlins/rockon.gif)
Right now I am just trying to remove 25 year old R12. Then I want to charge it and see where I stand. I have a r12 replacement kit with the dye,sealer and refrigerent. I also have a 134 conversion kit. I was able to build pressure enough for the compressor to kick on but the liquid that I can see in the drier lense looks like muddy water and the blower blows ambiant temp air.
