LSD who sells them?
I got an -86 32v with some minor modifications and I´m desperate to get an LSD, does someone know where to get one used or new, exept from Porsche.
Anyone here maybe?
Best regards
/Tobias, Sweden
Anyone here maybe?
Best regards
/Tobias, Sweden
Basic Sponsor
Also eBay and there are a couple on there at the moment
![](https://cdn.shopify.com/s/files/1/1694/8685/files/928sRus_rennlist.png?v=1621798567)
Does it have the "Do It Yourself" manual transmission, or the superior "Fully Equipped by Porsche" Automatic Transmission?
George Layton March 2014
928 Owners are ".....a secret sect of quietly assured Porsche pragmatists who in near anonymity appreciate the prodigious, easy going prowess of the 928."![thumbsup](https://rennlist.com/forums/graemlins/bigok.gif)
The limited slip replaces the ring gear carrier (differential housing in Porsche speak ) the unit with the differential pinions (spider gears) in it. So even though the tolerances are usually pretty good you must set up the ring and pinion depth and load when you change. Getting it out of the case is real easy just pulling the stub axles ,then you need to fit and test , shim as needed.
