928 Forum 1978-1995
Sponsored by: 928 Specialists
What's the trick to pulling relays?
Old 06-20-2008, 08:24 AM
sprio
sprio's Avatar
Default What's the trick to pulling relays?
I've tried grabbing it with hot dog tongs, twisting gently, and pulling - can't seem to get the darn thing out. Is there a trick, or do you just have to pull really hard?
Old 06-20-2008, 08:38 AM
Angel84-928
Angel84-928's Avatar
Search function =
https://rennlist.com/forums/showthre...ferrerid=48223
Other resource: http://members.rennlist.com/sharkski...04-Bzzzzzt.htm
Old 06-20-2008, 09:10 AM
gasmanstl
gasmanstl's Avatar
Here's what works for me: A screwdriver.
I took a plain bladed 6 inch screwdriver, and heated the tip red hot with a torch, and bent the last 3/8" or so at 90 degrees, like a flat hook. Thin blade screwdriver is essential. You simply hook the end of the tip under the base of the relay, at the corners, and pry a little, and then pull axially. It works as best as anything else I have been able to come up with.
Clay
Old 06-20-2008, 09:12 AM
Larry Velk
Larry Velk's Avatar
Paint can opener?
Old 06-20-2008, 09:16 AM
AO
Supercharged
AO's Avatar
What I have found that works best (and is a multi-purpose tool) is a paint can opener. They're free at Lowe's. They have a little hook on the bottom that works well for lifting them from underneath. Be sure to wrap a little electrical tape on them so you don't inadvertently short something out. They also work well as a bottle opener and I've heard you even open a paint can with them.
Old 06-20-2008, 09:56 AM
sprio
sprio's Avatar
Thanks, all, I'll give it a whirl this weekend. Angel, I hadn't managed to uncover the link to Sharkskin's pages in my searches - there's a wealth of information in there!
Old 06-20-2008, 10:06 AM
linderpat
linderpat's Avatar
Received 2,464 Likes on 1,327 Posts
Originally Posted by Andrew Olson
... Be sure to wrap a little electrical tape on them so you don't inadvertently short something out. ....
I would recommend always pulling off the ground strap first, before sticking anything metal down into or even near that CE panel.
Old 06-20-2008, 10:16 AM
aggravation
aggravation's Avatar
I use a spark plug puller.
Old 06-20-2008, 10:25 AM
Ispeed
Ispeed's Avatar
If they have been in there 20 years, they won't want to come out.
Pull all of them and put some dielectric grease on them and re-install. Better yet just get all new relays; the money spent there will be offset by fewer strange electrical problems and side-of-the-road problems.
P.S. fuses are cheap, we do all new fuses around here as well.
Old 06-20-2008, 11:14 AM
Imo000
Captain Obvious
Super User
Imo000's Avatar
If you use pliers (spark plug puller) and have a stubborn one, it will pull the housing right off the relay. You need to pull it from under the base or else the aluminum housing can pop right off.
Old 06-20-2008, 11:22 AM
AO
Supercharged
AO's Avatar
Yep... that's probably a good idea.
Old 06-20-2008, 11:33 AM
DonT
DonT's Avatar
Relay removal tool
link ---
http://www.kalyx.com/store/proddetai...665.0/file.htm
Old 06-20-2008, 12:13 PM
Alan
Electron Wrangler
Alan's Avatar
NO! NO! NO!
Just disconnect the battery - EVERY TIME! Andrew you should be ashamed...
lets keep blackened shark to strictly the restaurant domain...
Alan
Old 06-20-2008, 12:21 PM
sprio
sprio's Avatar
Fear not, even though I am somewhat of a noob, I did disconnect the battery. Lord knows, I don't want to do something that will result in more problems down the line.
Old 06-20-2008, 12:23 PM
AO
Supercharged
AO's Avatar
Originally Posted by Alan
NO! NO! NO!
Alan
No shame here... just a little embarassment. *ZAP* **ZZZAAPPP** *pooffff......*
Quick Reply: What's the trick to pulling relays?
