Lifter Problems
Lifter Problems
I checked my valve lifters after SITM and found 8 that are suspect of being collapsed. I have them soaking in varsol, however they are not responding with any spring movement. I checked threads and found out I need to preload the lifters with oil and found the bad lifters. Does any one have 8 used lifters they may want to part with ( early 86 auto)? I am communiting from Virginia to Pittsburg Pa. for work these days so it is going to be difficult to finish the 10 year labor of love.
Thanks,
Bill
Thanks,
Bill
Bill,
I have used lifters from a 1987 S4, but I don't know if they are the same as an '86. I know that all my lifters were not bad, but in the frustration of trying to sort out and test each one, I just bought all new ones. (38$ ea. X 32)
It ended up that I had 2 bent valves. The engine was very clean and the few lifters I took apart were not cloged or dirty in any way. There was no varnish build up on any kind.
The ones I have do pump up and stay hard, when you drain out the oil they are springy...
I have about 25 untouched lifters available.
If you are interested I would sell 8 for $80.00 and throw in a couple extra free to play with.
See this thread it might help. Good luck
https://rennlist.com/forums/showthre...ghlight=lifter
Big Dave, I understood that prior to installing the lifters in the heads (only after I had finished installing the cams in the 1-4 head) that oil had to be in them, soaking or injecting them some how with oil. When I was trying to clean and check the springs I found 8 to be "immovable" no movement when I pressed down on them. So I am getting the impression the springs are collapsed. All the other ones have spring action when I press down on them. I am going to re read the threads and see if I am doing something wrong.
Dave, I'll pm later.
Thanks guys.
Bill
Thanks,
Bill
Thanks guys.
Bill
Thanks,
Bill
