928 Forum 1978-1995
Sponsored by: 928 Specialists
Handbrake in the way...
Old Jun 16, 2008 | 02:22 PM
LightStriker's Avatar
LightStriker
Default Handbrake in the way...
Sorry if I'm asking a load of stupid question as new comer...
Anyway... I search about handbrake mod and didn't find anything conclusive...
Anybody moved the handbrake? I find it currently horribly in my way when I get in and out of the car. Is it possible to put it in the middle?
Old Jun 16, 2008 | 02:26 PM
Jim bailey - 928 International's Avatar
Possible ?? not really and certainly not practical . You might try adjusting it so it engages lower....just be sure it releases completely.
Old Jun 16, 2008 | 02:32 PM
FUSE69's Avatar
FUSE69
Put in racing seats with high side bolsters... handbrake won't be in the way anymore
Old Jun 16, 2008 | 02:34 PM
LightStriker
It's maybe at how high it engage... but really engaged is almost 45 degrees. Which is almost impossible to get in or out of the car without bumping your leg on it.
Even when I don't fully engine it and leave it parallel to the seat level, it's still likely to bump into it.
Old Jun 16, 2008 | 03:25 PM
ew928's Avatar
ew928
Owns the Streets
Needs Camber
Vaguely remember it being 3 or 4 clicks to full engagement for proper adjustment.
45 deg. seems a little high.
Old Jun 16, 2008 | 03:29 PM
Mike Frye's Avatar
Mike Frye
Craic Head
You get used to it.
I once drove a car that had the parking brake on the side like the 928, but it would go down when you let go, maybe a Fiero? You would pull it back up and push the thumb in to release, then let it pull down again.
Maybe you could modify it to work like that.
Old Jun 16, 2008 | 03:32 PM
Alan's Avatar
Alan
Electron Wrangler
It should not be in your way at all.. something is wrong - post a picture of how it looks?
When adjusted correctly you won't worry about it - its another almost unique thing about the car that certainly doesn't need to be fixed by relocating it... just fixed.
Before I bought my first 928 - I thought it was an odd position too - now I think its a really good idea...
Alan
Old Jun 16, 2008 | 03:35 PM
jthwan22's Avatar
jthwan22
AT trans rules. I don't use parking brakes.
Old Jun 16, 2008 | 03:54 PM
LightStriker
I heard it's maybe bad to use the trans park to block your car... Something about overusing some part.
Old Jun 16, 2008 | 04:24 PM
shmark's Avatar
shmark
I like it and it helps to keep the seat bolsters in good shape. Adjusted properly it should just be level with the seat bolster when engaged. The 944 and 914 are the same way so Porsche liked the design for a long time, kind of wish they still used it. And ignition switches should be on the left too.
Old Jun 16, 2008 | 04:26 PM
Alan's Avatar
Alan
Electron Wrangler
Originally Posted by shmark
...and ignition switches should be on the left too.
You'll be wanting the engine in the back soon...
Alan
Old Jun 16, 2008 | 04:30 PM
ew928's Avatar
ew928
Owns the Streets
Needs Camber
Alan
Mark, just remove the rear spoiler and drive the 928 backwards.
Don't think anyone's dabbled with rear engine front drive yet.
Old Jun 16, 2008 | 04:36 PM
6.0-928S's Avatar
6.0-928S
If someone bumps the car when parked without the handbrake it could snap off the parking pawl inside the trans.
Hammer
Old Jun 16, 2008 | 04:45 PM
shmark's Avatar
shmark
Hey it's more aerodynamic in that direction anyway! Just a little lift, that's all.
Old Jun 16, 2008 | 04:49 PM
Ispeed's Avatar
Ispeed
The later GTS hand brake handle bends down more towards the floor to stay out of the way better. If it's adjusted correctly it doesn't come up much.
