Air intake tubes
Thanks for that - prompted me to go search and voila:
https://rennlist.com/forums/showthre...uri+turbulence
Includes a post by Erkka of a part of the WSM that does indeed indicate its for noise supression.
I have the type that uses the Mercedes tubes with a silicone joining section as seen in Post #9. The section is available in red, Blue and Black for $75 a pair plus shipping.
Does it have the "Do It Yourself" manual transmission, or the superior "Fully Equipped by Porsche" Automatic Transmission?
George Layton March 2014
George Layton March 2014928 Owners are ".....a secret sect of quietly assured Porsche pragmatists who in near anonymity appreciate the prodigious, easy going prowess of the 928."
I think the Mercedes type tubes are a similar material to stock S4 - and though they may eventually get a little more brittle (as the stock ones do) - they should last a long time - that's what they were designed for...
The neoprene is rated for 300F and harsh chemical environments so I expect it will also last pretty well - I've had it on for about 2 years and it still looks new - cleans up really nicely too.
Go here : http://polycarbonate-plastic-resin.c...lass-2-Ply.htm I used the KH512 if I recall correctly. But note late airbox intakes are different than earlier ones - measure... The 12 foot length is enough to do 2 cars... since they only sell it in 12' lengths you have to in with someone. It looks neater with the end covers from the stock tubes (GTS only) - otherwise you have the spiral wire to end.. it wants to go tangential...
If you are worried about airflow - see how smooth the inside of GTS tubes are (and how crappy they look after about 10 years...)
