Unknown wires...yes another one ;-) - Solved
I am installing a navigation system today, and looking for the reverse signal on the CE panel. I come accross some loose wires and non-factory looking connectors. There are two connectors, one red, one white, and a wire that sorta looks like a antenna.
Does this look familiar to anyone? Amp? Alarm? Radar? Flux capacitor? Don't-know-thingie?
Pretty certain they aren't factory connectors.
Previous alarm/immobiliser installation ?
The antenna looking wire possibly for a remotecontrol for the above or for a remote central locking install ?
Looks like you need to play detective and find what (if anything) the other ends of the wires are connected to in order to suss out what they do/did.
All those connectors back there are aftermarket - figure out what they connect to... There should be no splices.
Anything not red connected to the top busbar is also suspect...
Do you know where to find the speedo signal? - you didn't need to take the panel out...
Alan
Alan
I got the speed signal off the back of the cruise control unit and the reverse of U21 on the CE panel. That's where I noticed the loose connectors and loosened the CE panel to investigate further.
