928 Forum 1978-1995
Sponsored by: 928 Specialists
Is the crank bolt reverse threaded? ( Noob Question)
Old 05-20-2008 | 12:17 PM
Fabio421's Avatar
Fabio421
Man of many SIGs
Default Is the crank bolt reverse threaded? ( Noob Question)
I think I know the answer to this question but I just want to be sure. Is the crank bolt, the one that holds the pully's and gear onto the crankshaft, normal or reverse threaded. In otherwords, is it lefty loosey, righty tightey or is the other way around. I have been trying to loosen this darn thing but it is freakin' on there good. I am about to go all midevil on its @$$ and throw some heat to it. But before I continue I just wanted to double check the rotation.
Old 05-20-2008 | 12:20 PM
AO's Avatar
AO
Supercharged
Nope... regular righty tighty - lefty loosey.
Old 05-20-2008 | 12:34 PM
SteveG's Avatar
SteveG
My breaker bar is IIRC 28". Once I added a cheater to that. Not ashamed to admit it.
Old 05-20-2008 | 12:36 PM
AO's Avatar
AO
Supercharged
I use a 1/2" drive cheater bar with a 4' pipe extension and even that has issues sometimes.
Old 05-20-2008 | 12:37 PM
Big Dave's Avatar
Big Dave
928 Engine Re-Re-Rebuild Specialist
HA! Girly men!
(I use the 3' handle from my lift as a cheater bar on the end of my 1/2" 3' long breaker bar)
Old 05-20-2008 | 01:07 PM
rixter's Avatar
rixter
928 OB-Wan
I use a 3/4" with 3' breaker bar, comes right off and I'm a little guy
Old 05-20-2008 | 01:10 PM
Fabio421's Avatar
Fabio421
Man of many SIGs
I've got a big honkin 5' long snap on 3/4" ratchet I could use. I just don't know if I have an 1 1/16" socket to fit it. Hmmm? I'll go check.
Old 05-20-2008 | 01:14 PM
kary4th's Avatar
kary4th
You don't qualify as a noob, Shawn.
Old 05-20-2008 | 01:23 PM
Jim bailey - 928 International's Avatar
they are often very ,very tight.... use a longer bar
Old 05-20-2008 | 01:39 PM
BobS!'s Avatar
BobS!
Took about 5 feet for me.
Did not need to go with the brace up the bar and hit the starter thing but it was close.
JimBob951's Avatar
JimBob951
I used a 1/2" breaker bar, and the handle from my floor jack and broke the end off the breaker bar!! then tried a 3/4" breaker and 1 1/16" socket and just managed to round the bolt!! Then took out the radiator and used the impact wrench with a gator grip! Still haven't got it off!!!! arrggghhh!! Was gonna try heat next too!!!
Shawn, if you get yours off let me know how you did it!! (and then maybe you could come up and help me! lol)
Jimbob
Old 05-20-2008 | 01:53 PM
Some people unfortunately have used Loctite on the crank bolt as well as a really big rattle gun on high pressure air...they get really tight. I also hear about bolts backing out once in a while so some are also too loose...
Old 05-20-2008 | 03:26 PM
RyanPerrella's Avatar
RyanPerrella
yeah, so when you put it back on, save the next owner or yourself some trouble and tighten to the factory torque specification. I think its 212 or 252 or 2 something, double check it first then tighten it up to that and its all good, NO LOCTITE
Old 05-20-2008 | 03:34 PM
Rod Underwood's Avatar
Rod Underwood
Soaked it overnight in Kroil and then took it right off with an impact wrench.
Lucky, I guess.
Rod
Old 05-20-2008 | 03:53 PM
checkmate1996's Avatar
checkmate1996
27mm deep socket - 3/4" rachcet with 6 foot steel pipe!!!
Quick Reply: Is the crank bolt reverse threaded? ( Noob Question)
