am i still safe with cam timing
there is enough wear on my left cam gear that i want to replace it i was'nt thinking about marking them now my belt is off and the bolt holding both gears are loose so the gears may of moved from its original position no more than 1/8 to 1/4 if they moved at all i was told to loosen well belt was still on im not making more work than need be am I
