a/c problem
Symptoms: gradual loss of a/c
steps taken: replaced expansion valve.
anti-freeze switch and pressure switches replaced last year.
put 24oz of R12 in system.
a/c clutch will not engage. Tried jumping freeze-switch and pressure-switch. No difference.
Freeze switch has 4.5 vdc one side and 0 vdc the other.
Together they have 10 vdc. Pressure switch has 12 vdc. Clutch is not frozen.
Sounds like the relay in the head unit is a possibility. try just feeding 12v to the freeze switch (& therefore to the clutch)- does it work then ? if yes you need the head unit relay fix.
Alan
Alan
I don't have the WSM here, but the sticker on my car says 33 oz no rear air, 37 with. At best you are 9 ozs low. Yes, jumping the low press switch should do it so Additionally, the voltages you are getting suggest Alan's course.
