928 Forum 1978-1995
Sponsored by: 928 Specialists
A/C not working....
Old May 16, 2008 | 06:00 PM
Joe F's Avatar
Joe F
Default A/C not working....
Car (83 Euro S) went to the shop to get the odo gear and a couple of leaky gaskets replaced. When I got it back, the A/C blows hot air. Is there a fuse that could be blown or a wire disconnected that could cause this. When I turn it on, I can hear the flaps in the console doing what they are supposed to do but only hot air coming out.
Of course the A/C worked fine when it went in there. Any thoughts?
I tried search, but there were so many answers it would take the rest of my natural life to read all of them.
Thanks in advance.
Old May 16, 2008 | 06:36 PM
Mrmerlin's Avatar
Mrmerlin
Team Owner
need more info on all of the work done please be specific it sounds like someone has also FIXED the AC system for you
Old May 16, 2008 | 07:29 PM
Joe F's Avatar
Joe F
Sure they did and on a day that is nearly 100 degrees too, what givers they are!
work done.... replace odo gear, so speedo R & R
change gear oil to amsoil in gearbox & diff.
Repair leaks....
R & R oil filter housing gasket
R & R thermostat housing gaskets.
Any clue there?
Old May 16, 2008 | 07:33 PM
PorKen's Avatar
PorKen
Inventor
Is the compressor turning, Mr. Takes-His-Car-to-the-Shop?
Old May 16, 2008 | 07:46 PM
linderpat's Avatar
linderpat
the mechanic probably knocked the vacuum line off the hvac valve that sits behind the airbox on the firewall in the engine bay. It may be a blue vac line? Anyway, check that first, as the disconnect of that vacuum line will disable air and give you heat instead...
Old May 16, 2008 | 07:50 PM
Joe F's Avatar
Joe F
Should have known you'd be on here bustin' my chops.
Don't you have something to invent?
Old May 16, 2008 | 07:56 PM
Jim bailey - 928 International's Avatar
The power supply wire to the A/C clutch runs down the right front of the motor connects to the compressor just rear of the pulley. Give that 12 volts and the clutch SHOULD engage ,the compressor SHOULD turn , and it MIGHT refrigerate.
Old May 16, 2008 | 08:44 PM
Joe F's Avatar
Joe F
Unfortunately, the answer to the question is no, it is not turning. I will try Jim's suggestion. Fortunately, Porken felt sorry for me and offered to help, sooo we should know the problem soon.
Thanks all for your comments.
Old May 16, 2008 | 08:50 PM
PorKen's Avatar
PorKen
Inventor
Old May 16, 2008 | 09:41 PM
Bertrand Daoust's Avatar
Bertrand Daoust
+1. Check that first. I had the same problem and it was the connection that was disconnected.
The connection is near the oil dipstick.
Old May 17, 2008 | 02:05 AM
Joe F's Avatar
Joe F
Did that. Clutch did engage, compressor DID turn. Did not refrigerate. BAH
Low gas appearently causing compressor to shut down. Double BAH
sounds like $500 give or take...............
