Electrical Puzzles – ’87 S4 Interior Gremlins
Maybe some of you electrical gurus can give me some advice in troubleshooting the various electrical gremlins that I'm chasing around in my '87 S4. Sorry if the post is a bit long and disorderly, but I've got to start somewhere.
Basic history of the car is that it had a 5-speed conversion done sometime in the past, several PO’s ago (which could be the reason for some electrical oddities) and other than that, there really is no existing history; I got the car w/o service records or option codes and with some of the interior disassembled where there was obvious electrical problems that were ongoing but not resolved. I've ignored them thus far because the car drives fine and the glitches seem to only affect non-critical items, but now I'm getting serious about fixing them.
I recently replaced all of the fuses and found that several were blown or the wrong rating for the application. This brought various interior features back to life. The interior lights began working again, but I figure the fuse will blow again unless I can find the short. I have to keep the light switches in the middle position off setting in between ‘always on’ and ‘off after doors close’ settings because otherwise they stay on. I plan to switch to LEDs soon so that they won’t draw much in case they inadvertently stay on.
So now I’m looking for the short. I checked the wiring when I replaced some dome bulbs and the ones I’ve seen were in order. I know that any interior light Brown/White wire swapped with the brown wire or shorted to any exposed metal/ground point will circumvent the dimming feature and cause interior lights to stay on.
There are several severed wires around Ground Point ‘MP IV’ that you can see in the below grainy camera phone photo. These wires have just been laying there like this... Note, after I took the photo I taped up all the ends with electrical tape. I'll go back and see which have power to them and try to correlate them with controls and features this weekend when I get back into it. There is also another severed wire that is not in this picture that I just discovered later today after I had taken this photo. It is also in the rear but on the gas tank side of the car.![Confused](https://rennlist.com/forums/images/smilies/confused.gif)
![](http://i52.photobucket.com/albums/g22/Gullstrom/Porsche_928/severedwiresspare-tirehatch_050508.jpg)
The green severed wire-1 looks like it feel out of the adjacent plug, but the wires out of the plug are brown and brown/white. I couldn't find that combo in the wiring diagram. The other wires look like they might have been accessories, particularly severed wire 3 just looks like speaker wire. Possibly wires 2 & 4 were grounds, but aren't grounds brown in these cars, with brown/white grounding to relays? I couldn't find too many black wires in the diagram that looked like they would live in this vicinity...
I’ve been looking at the factor wiring diagrams to see what systems ground to MP IV.
The ‘interior lamp contact switch’, ‘interior lamp roof’ and ‘interior lamp trunk lid-2’ all ground here. It also appears that the speedometer impulse sensor grounds to MP IV. Since the speedometer/odo is still not working, this would be the next logical place to fix in troubleshooting this. I will be able to get under the rear of the car soon to verify that the pick-up is still attached properly. If these don’t fix the speedo then I’ll tear into the dash pod as soon as I have time.
The only other feature that appears to use this ground point MP IV is the Rear Wiper motor and relay. The rear wiper hasn't functioned since I've had the car. I may just take 'delete' it to save weight and clean things up since I never used that on my other 928 anyway.
You can see in this picture of the fuse/relay panel taken right after I replaced all the fuses that two relays are missing and are jumpered; the XIV Starter Relay and the XXII Reverse Light Relay, which is called the Reverse Light Bridge for 5-speeds, so maybe it is supposed to be like this now?
![](http://i52.photobucket.com/albums/g22/Gullstrom/Porsche_928/fusebox-relays5_050508.jpg)
Does the having power always on to the Starter circuit cause any problems w/o the relay switch in place? Is it possible that this was done because the circuit was different for the manual transmission and the stock relay was for an automatic?
Speaking of automatics, my dash auto-trans gear indicator lights come on since I replaced the fuses, and since the car is now manual this is annoying. Any idea which fuse controls this? I have gone back through the fuse diagram/labels and there is no clear indication of which fuse controls these lights and whether that fuse is also used to power anything else. I could go through and pull fuses until the light goes off, but w/o testing the other controls, some of which are still not working, I won’t know if I am taking power away from another function as well. I would eventually like to remove the bulbs, or better yet to swap the tach face plate for a manual one. Anyone have a suggestion on the best way to deal with this?
Thanks for advice on any of these matters![jumper](https://rennlist.com/forums/graemlins/jumper.gif)
Chris
Chris
Electron Wrangler
...appears that the speedometer impulse sensor grounds to MP IV.
The only other feature that appears to use this ground point MP IV is the Rear Wiper motor and relay. The rear wiper hasn't functioned since I've had the car. You can see in this picture of the fuse/relay panel taken right after I replaced all the fuses that two relays are missing and are jumpered; the XIV Starter Relay and the XXII Reverse Light Relay, which is called the Reverse Light Bridge for 5-speeds, so maybe it is supposed to be like this now?
Alan
Team Owner
as always disconnect the battery when working on the elex system
Awesome advice, thanks guy! ![thumbup](https://rennlist.com/forums/graemlins/thumbup.gif)
Oh, and yes the reverse lights do work fine.
I checked to make sure the brown and brown&white wires weren't crossed on some of the interior lights but not all, I will go back through more thoroughly.
BTW, I meant to type 'MP VI' and noticed I'd been typing MP IV, a differnt ground point... damn dyslexia
