Exhaust leak = valve damage???
I had some exhaust work done on the Euro last week and the tech, using a stethoscope, said he could detect a small leak where the pipe attaches to the manifold on the passenger side. I can't hear any leak so I told him to leave it alone.
The question is, could a small leak at that point possibly cause any damage in an overhead cam set up?
No, damage to the exhaust valves can happen from a major leak at the head. Running an engine with no manifold would damage valves, not a minor leak downstream.
A leaking exhaust valve can let unburnt combustion gases into the exhaust header which can detonate and cause a leak, but not the other way around. Did the tech do a compression test on that cylinder?
Dennis
Dennis
Chronic Tool Dropper
Charley--
That's a gasketed connection, easy enough to replace the gaskets and probably the bolts/hardware at the same time.
For those playing at home, the concern is that cold air will be drawn back to the valves on shutdown, risking warpage of the valves. There are urban legends associated with this, mostly with folks who ran engines hard enough to glow the valves with no exhaust at all. If it's a leak too small to hear, I wouldn't give the valve damage issue a second thought.
Bob,
The concern about the cold air was very real. Prior to the incorporation of catyltic convertors and valves designed for hotter running, Detroit auto makers placed temp controlled valves on the exhausts to slow the cool down. With today cats and better engineered valves, it shouldn't be a problem.
Dennis
Dennis
Bob,
Dennis
Dennis
It had absolutely nothing to do with keeping cold air off the exhaust valves.
Bob,
Guess I should have been more specific on my time line. I was specifically refering to the old Ford Y blocks (made until 63) that had the passenger side exhaust wrap around the front of the engine, go into the drivers side manifold, then exit through a valve to the exhaust. My pet peeve was that the valve was spring loaded and would often freeze up and stall the engine. IIRC the Plymouth flat head engine (made until 59) had the valve just before entering the exhaust also. You are right in that the later V-8's with automatic chokes only used it for heating the manifold.
Dennis
Dennis
OK, now I know what you were referring to. It's easy to date our knowledge when we can think back to 292/312 V8's and remember how the little spring-loaded exhaust flapper valve worked. But can't remember what we had for lunch yesterday. I can't remember the last time my memory was good...
What's memory?
Dennis
