RHD 928 - Pic of Coolant hose position by PS Reservoir
Right Hand drive answers only (LHD doesn't have a coolant hose at this location)
I need a pic of the location of the coolant hose that goes from the Tstat bridge to the steel Y piece on the side of the Passenger (left) side inner wing. specifically how it routes around the pass side cam cover and distributor cap.
I am farting around with the PS hoses and the coolant hose gets in the way I can't refer to the SE as it it has a non standard coolant hose that runs a different way.
Pic below shows what I am looking at - PS res is temp removed.
TIA
TIA
TIA
TIA
Edit: Here's a couple.. I might have to take one, call my mobile if these aren't enough (its in the garage with me)
It routes pretty much where you have it shown in the pic above - it then threads through the loop made by the PS hose as it passes the timing belt cover.
In the first shot, you can see it beneath the two PS hoses as it passes along under the edge of the cam cover to the steel Y-connector.
In the shot where its disconnected during my TBWP, its routed as normal except folded upwards, so you get a shot of it going past the PS hose.
Thankx Bert and Hilton
I got it correct it looks like. As I said earlier I couldn't use the SE as a reference, and the GT has new MMs so that area seemed a lot tighter than the SE which still needs new MMs.
