ID an engine by the numbers?
Just in case things don't go well with my glass bead removal project, I picked up a complete replacement engine. Good runner with 90K on it. Very dry, no leaks anywhere.
The seller claims it is an 82' 4.7 Non-"S". I was looking for a simple 4.5 and I think that is what I have. The number is M28103 8290490. Can anyone tell me how to decipher the numbers?
How would this engine be better or worse than my original 79' ? Cams the same? Compression the same?
Go to www.928gt.com under Tips/Links and Tech spec.
Dave has all of the engine codes listed by year and type.
the first 8 is for 8 cylinder
For details according to PET
Cheers
marton
HTML Code:
VEHICLE TYPE__________TYPE___MY_____ENGINE NO.TECHNICAL DATA 928___________________M28.01 79 9 819 0001>5000 8ZYL/4,5L/177KW 928 M249______________M28.02 79 9 819 5001>9999 8ZYL/4,5L/177KW 928 (USA)(CDN)(J)______M28.03 79 9 829 0001>5000 8ZYL/4,5L/169KW 928 M249 (USA)(CDN)(J)_M28.04 79 9 829 5001>9999 8ZYL/4,5L/169KW
marton
As second row says its 490th '79MY manual gearbox engine for US market. Its possible numbers didn't start from 0001 even though factory papers say so but its certainly in the middle of '79 MY production. Very likely made in late 1978.
