928 Forum 1978-1995
Sponsored by: 928 Specialists
Cigarette lighter
Old 04-27-2008, 04:04 PM
Hi Ho Silver
Hi Ho Silver's Avatar
Default Cigarette lighter
Does anybody know how to get this to work, it clicks in but is not heating up and the light is not coming on, has anyone got pictures of the wiring set up, maybe mine is incorrect.
Old 04-27-2008, 04:10 PM
SeanR
SeanR's Avatar
Pull out your ash tray, use a test light, with your ignition turned on and see if you have any power going to it.
If not, check your fuses 1st, then the wiring.
Old 04-27-2008, 06:36 PM
Hi Ho Silver
Did a test, power was there, had to adjust the clips that hold the lighter, works now, not that I smoke but I like everything to work. Many thanks
Old 04-27-2008, 06:37 PM
SeanR
SeanR's Avatar
Glad to hear it works. Job well done.
Old 04-27-2008, 07:08 PM
Charley B
Charley B's Avatar
Whew. Thank god you don't smoke.
Old 04-27-2008, 07:30 PM
imfinlay
imfinlay's Avatar
How bizarre - I just did the exact same job on a friend's '83!
Old 04-29-2008, 01:56 PM
928autobahndreamer
928autobahndreamer's Avatar
Just a quick question on the cig lighter. As I was pulling in to my parking spot at work I noticed the cigarette lighter and wondered if it worked. So, like a 2 year old I had to push the button. Problem is that the button didn't pop back up.
So, the question is this. Does power go to the unit once I turn the engine off or remove the key? I want to make sure I don't either kill the battery, or set my car on fire from the cig lighter staying hot.
When I get home I'll pull the ashtray and see if I have power or if I need to adjust the clamps........that is if the battery hasn't gone flat or I haven't had a Car-B-Q.
Old 04-29-2008, 03:17 PM
AO
Supercharged
AO's Avatar
Unless your is direct wired, the power should be cut when you turn off the ignition.
Old 04-29-2008, 04:21 PM
EC928NC
EC928NC's Avatar
Interesting thought... I don't have a schematic, but I wonder if the lighter is tied into the door solenoid circuit. The power windows will work with the key off until a door is opened... I wonder if the lighter does too?
Old 04-29-2008, 05:41 PM
Jim bailey - 928 International
Jim bailey - 928 International's Avatar
Some years the lighter is powered all the time and allows you to use the battery float charger plugged into the lighter socket the later models it is switched power and only powered when the key is on.
Old 04-29-2008, 07:31 PM
Charley B
Charley B's Avatar
You should be able to pull the lighter with your finger tips, even if it is in the down position.
Old 04-29-2008, 07:38 PM
Leon Speed
Leon Speed's Avatar
Excuse me, but it's a cigar lighter..Porsche drivers don't smoke cigarettes, but cigars...ahem
Old 04-29-2008, 07:50 PM
justin
justin's Avatar
Jim, the lighter in my '80 model only comes on with the key. Is that normal, or did somebody wire it that way?
TIA
Old 04-29-2008, 07:54 PM
I am not sure what years do or do not, just that they vary. I never use the thing myself.
Old 04-29-2008, 08:08 PM
jorj7
jorj7's Avatar
I lost my cigar lighter when I installed the supercharger kit. Last year I needed
one again for the new GPS, so we put one in next to the center console. The
only problem was that it only worked when the ignition was off. Of course when
we tested it in the garage it worked fine. I didn't find out that it didn't work with the
ignition on until I started the car to go to the race (you know last minute preparations).
Had to scurry to find another power source once we got there.
Now it's on all the time.
Quick Reply: Cigarette lighter
