928 Forum 1978-1995
Sponsored by: 928 Specialists
Fuel Dampner 928.410.429.07 ? no it's a vacuum limiter, PN 928.110.173.01
Old 08-14-2013, 12:34 PM
  #31
syoo8
syoo8's Avatar
Just to clarify:
My 'control valve' 928 110 429 07 will only hold vacuum if both of the larger ports are plugged. My understanding is that:
No vacuum: ports are closed to pass vapors
Vacuum: ports are open to pass vapors
There must be some kind of diaphragm in there. Anyone ever try to fix one of these?
Old 08-14-2013, 12:39 PM
  #32
Mrmerlin
Team Owner
Mrmerlin's Avatar
Received 2,432 Likes on 1,365 Posts
this is a sealed unit,
replacement is to find another part that holds vacuum,
buying a new one for 700.00 is ridiculous,
maybe Roger knows where to find another part that costs less
Old 08-14-2013, 01:54 PM
  #33
dr bob
Chronic Tool Dropper
dr bob's Avatar
Try 928 International for a healthy used one. Unfortunately, backfire through the intake is death on these parts. Fortunately, if the diaphragm holds vacuum it's all intact.
Old 08-14-2013, 03:59 PM
  #34
Mark Anderson
The Parts Whisperer
Mark Anderson's Avatar
Thanks Dr Bob,
We do have a good used for $60
Old 08-14-2013, 05:26 PM
  #35
Eplebnista
Eplebnista's Avatar
My dear departed mother used to look at me every once in a while and say "Never trust a diaphragm." I guess she knew I would own a 928 someday.
Old 08-14-2013, 11:28 PM
  #36
syoo8
syoo8's Avatar
E-mail sent to you Mark.
Old 08-16-2013, 12:50 PM
  #37
Mark Anderson
The Parts Whisperer
sorry but i have not seen it yet
Old 01-27-2019, 10:13 PM
  #38
Ramp
Ramp's Avatar
Originally Posted by Fabio421
Heres a pic of the part in question
Resurrecting this for a side question - does anyone know the part # for the rubber lined clamp that holds this control valve to the cross brace ? It does not appear in the PET.
Old 01-28-2019, 12:16 AM
  #39
polecat702
Vegas, Baby!
polecat702's Avatar
It's called an Adel Clamp, about a buck at Home Depot.
Old 08-26-2019, 02:24 PM
  #40
coach928
coach928's Avatar
Default How to make the vapor control valve look new?
Sorry to dredge up an old thread…
I have the same problem that mervynp has encountered. My 928.110.429.07 "Control valve" will not hold vacuum.
Attachment 752488
After scouring Rennlist about this part, this is what I have learned thus far:
This control valve is part of the fuel vapor charcoal container system and under certain conditions it pulls air through the container to purge the accumulated fumes. It will affect performance if not working properly, or if there is a vacuum leak from being disconnected.
This control valve is one of the few parts of my engine bay that is not shiny. I assume that plating it would ruin the diaphragm inside, right? What's the best bet to make it look new? Mask and paint?
Old 08-26-2019, 06:42 PM
  #41
Eplebnista
Eplebnista's Avatar
You can still plate it if all the ports are capped off. It won't float. Mine survived re-plating just fine with some tight fitting caps over all the openings. Since the back half or body is not plated, you can mask that off by brushing on liquid paraffin and letting that harden. As long as your plating solution is around room temperature, the paraffin will prevent the body from being plated or stained by the chromate dip..
Old 08-26-2019, 08:00 PM
  #42
dr bob
dr bob's Avatar
IF, and that’s an uppercase IF, you can plug all the ports and protect them from the chem clean, strip, clean, and plating solutions, you can get away with replating. It’s likely not the diaphragm that’s at risk, it’s the metal pin and the seal around it that lift the valve disk inside.
Old 08-27-2019, 07:32 AM
  #43
Ramp
Ramp's Avatar
I covered the ports and sprayed it with Eastwood Silver Cad and 3 coats of their Diamond Clear. Looks brand new.
Quick Reply: Fuel Dampner 928.410.429.07 ? no it's a vacuum limiter, PN 928.110.173.01
