Noisy Suspension
Any one else have this problem? The suspension is noisy..It groans and creaks when you drive it. Is there a way to stop this? Can you lube up or grease the suspension components like the shafts of the shocks etc? Any Ideas? Thanks in advance this group is the best...Bill 84 928s
If its from the front, it is most likely bad ball joints. If the rubber boots tear and the grease runs out, your car will sound like a rusty farm tractor. Mine are bad...
Normy-
'85 S2 5 Speed
Normy-
'85 S2 5 Speed
Barry and Norm...Thanks for the replies.Barry I have only owned the car since last May.I would guess that the shocks and springs are originals.They look quite old anyway. Normy, I had the oil changed 2 weeks ago today and at that time the mechanic and I went over all the suspension components ball joints ,boots ,rear axle boots ,and the alternator connections. I did notice that the ball joints are the grease less or should I say the grease nippleless variety. Thanks guys I'll see if I can find where the irritating noise is coming from...tnx Regards
Bill 84 928s
Bill 84 928s
Has there ever been any work done on your car that required revoval of the transmission and or torque tube? It is possible that the rear upper control arms are installed incorrectly and they are rubbing on the sway bar. This had been done on my car and it took me a long time to find it. the upper control arms should be installed with the curves going towards the ground. I have pictures on my website that show this problem. I hope it is not the problem on your car
<a href="http://members.rennlist.com/jumpytoad/" target="_blank">web
page</a>
<img border="0" alt="[cheers]" title="" src="graemlins/beerchug.gif" />
page</a>
I have the same problem with my 84 928 S, I have new ball joint practically new everything and it still does it, I have put lithium grease and wd 40 anywhere I could but I'm guessing maybe the shocks so those are next to replace. let me know if you find out anything more,good luck
DrJeremyB
DrJeremyB
Bruce...Thanks for the heads up on the rear upper control arms..Yes the torque tube and clutch was rebuilt about 6k ago, I'll have to check that out...3yrs according to records,the work done on car was to the tune of 8k dollars..geepers pretty steep I'd say.....
Bill 84 928s
Bill 84 928s
