Help! passenger door lock stuck in locked position
I have applied as much force as I dare with the key and with the **** on the inside. Cant move it out of locked position.
I would be greatful for any input on how to best approach this situation.
Can I access the necessary points with the door closed/locked?
Many thanks,
1991 GT Euro
The least expensive way is to use force on the internal **** and twist it.
That worked when I have been in this situation and replacing the **** is pretty cheap.
Once you have the door open you need to remove the panel and find out what is going on before it happens again.
Does it have the "Do It Yourself" manual transmission, or the superior "Fully Equipped by Porsche" Automatic Transmission?
George Layton March 2014928 Owners are ".....a secret sect of quietly assured Porsche pragmatists who in near anonymity appreciate the prodigious, easy going prowess of the 928."
