It's Alive!!!!
We had a choice?
I've exhausted my limited knowledge. I've done searches, but none seem to duplicate my problem.
Does not want to start or even fire at all most of the time
Spark is weak (not blue), but present.
When it does start, with a lot of cranking and holding the gas pedal to the floor, it runs very rough, will not idle, blows black smoke. (Rich mixture?)
New plugs black and sooty (dry) (Rich mixture?)
I don't think it is actually a fuel problem. I'm leaning towards ignition.
Cap/wires/coil 2 years old.
Ignition control unit has been changed out with a known good unit.
All grounds cleaned.
The distributor is the original M28/11 distributor.
I have tried adjusting the fuel distributor and make no difference.
I have changed every item in the fuel system over the last 2 years, and I mean EVERY item.
Discussion, please.
Discussion, please.
We had a choice?
We had a choice?
Wedge-open air valve ( if big vac leak, then not enough suction makes it to the air valve to overcome the spring)
(Just firing-out things I've dealt with, hoping I don't make it too twisted for Allen or Merlin who will soon come in here and apply real logic and help you, as they have many of us!!!!)
We had a choice?
Don't flame me guys, but i squirted some starter fluid into the lower plenum through the plate( I know, I know).........nothing, just the engine turning over, no attempt to fire.
