928 Forum 1978-1995
Sponsored by: 928 Specialists
Sun roof
Old May 4, 2003 | 07:18 PM
goodspeed928's Avatar
goodspeed928
Post Sun roof
The f34king sun roof rip the piant off
my car today and I PI$$ED!!!!!!!! <img border="0" alt="[grrrrrrr]" title="" src="graemlins/cussing.gif" /> <img border="0" alt="[grrrrrrr]" title="" src="graemlins/cussing.gif" />
It was stuck a little, so I grease the tracks
cleaned the EVERTHING, took of the cover and
check the it all, <img border="0" alt="[grrrrrrr]" title="" src="graemlins/cussing.gif" />
Now I need a paint job$$$$$
NOW it go's back and forth ****ie and RIPS
THE paint off the top of my car.
I looked at 3 hours of info on the WEB -
NO GOOD
HELP <img border="0" title="" alt="[Eek!]" src="eek.gif" />
Old May 4, 2003 | 07:28 PM
ErnestSw's Avatar
ErnestSw
Post
Sounds like the sunroof jumped the track and your efforts just enabled it to move in the wrong plane. Sorry it happened.
Old May 4, 2003 | 07:37 PM
Normy's Avatar
Normy
Angry
Yeah, Greg....I feel your pain.
Normy!
'85 S2 5 Speed <img src="http://boards.rennlist.com/upload/scrapes.jpg" alt=" - " />
Old May 4, 2003 | 08:16 PM
goodspeed928
Post
That IT!!!!!!
Old May 4, 2003 | 08:17 PM
goodspeed928
Post
How do I put it back on "plane"????
Old May 4, 2003 | 11:06 PM
Big Dave's Avatar
Big Dave
928 Engine Re-Re-Rebuild Specialist
Post
I've got the same problem. It's in the tracks, it's already been repainted once, and it only rubs once in a while. But once in a while is enough to make it look bad.
Mine scratches near the middle. The roof is properly positioned when closed, so I'm at a loss why it continues to scratch.
Old May 5, 2003 | 12:36 AM
Normy's Avatar
Normy
Cool
I'm eventually going to repaint my car true black, as it came from the factory. Until then...I'll just live with the scratched sunroof.
I was able to buff out most of the scratches. You can hardly see them anyway...
But it makes me think of shipping the sunroof panel up to my friend in Monroe, Michigan who does the Linex bed liners...and having him linex the thing!
<img border="0" alt="[hiha]" title="" src="graemlins/roflmao.gif" />
Normy!
'85 S2 5 Speed
Old May 5, 2003 | 02:50 AM
Ron_H's Avatar
Ron_H
928 Barrister
Cool
Goodspeed:
My sunroof did the same thing. <img border="0" title="" alt="[Eek!]" src="eek.gif" /> Scratched the paint in several places. I thought I had something jammed in there like a small pebble or twig. I tore it all apart and fouled the air with repugnant language.
Even went so far as to buy another sunroof panel in good condition the same color as my car as a replacement.
Finally, I figured it out. There are plastic blocks (one on each side of the opening) to which the front of the sunroof panel is screwed. 2 screws each. If you remove the screws the panel can be lifted out. The blocks seem to be attached to the cable. They control the relative height of the panel in the opening, and thus, if they are loose, the panel will not follow the ideal path as it moves rearward. In that event, it will jam and scratch as it rocks on the way back. I tightened the screws and no more scratching and jamming.
Of course the paint was screwed. But I stashed the aforementioned cherry panel in the garage for the future.
You will need to loosen the upholstery panel and slide it backward out of the way to access the loose screws in the black plastic blocks. It seems easier to see from inside of the car.
If you still have trouble, email me and I can explain further. <img border="0" alt="[bigbye]" title="" src="graemlins/xyxwave.gif" />
Old May 5, 2003 | 02:37 PM
928ntslow's Avatar
928ntslow
Post
Go to Greg Nicols site. I did a complete write up on the revamp of the sunroof with adjustments.
Old May 5, 2003 | 10:27 PM
goodspeed928
Post
Took the thing apart!
Still no go, cant keep the screw pin's
locked in place, why.
If any as photo's on how this sould BE.
Thank
Old May 6, 2003 | 02:26 PM
goodspeed928
Post
I think that Mike and I going to
take It off the car and start over.
We sent 3 hours playing with it, still
not right!
Old May 6, 2003 | 05:18 PM
928ntslow's Avatar
928ntslow
Post
Greg
What is a screw pin? Explain to me exactly the location of these and what you are doing.
Unless you have a broken part, this adjustment is rather easy.
GIve me your best explanation and I will walk you through it.
Old May 6, 2003 | 05:24 PM
928ntslow's Avatar
928ntslow
Post
BTW, you don't have to have your sunroof repainted. You just need to compound and glaze with maybe some touch up paint in spots. Cut it down with a 2000 grit Meguires sanding block and your looking fresh again.
If you need to know this proceedure, let me know.
Old May 6, 2003 | 05:57 PM
goodspeed928
Post
HO YES, The paint is cut thru -is BAD!
THE pin screw is 3/4 thead 1/4 non-thead
and needs to be in a small hole, it keeps
poping out. It go's to the shoe piece.
Old May 6, 2003 | 06:08 PM
Greg86andahalf's Avatar
Greg86andahalf
Post
Greg, any chance of posting a pic for us?
