928 Forum 1978-1995
Sponsored by: 928 Specialists
Torque tube Replacement
Old May 11, 2003 | 06:07 PM
Deb's Avatar
Deb
Post
Thanks Karl, I'll have a good look at the rebuilt tube when it arrives. I'm a little confused and maybe your experience will solve some of my ? The info I have seen, except for J. Bailey, is on 928's but automatics where they have removed everything but the ashtray to get the torque tube out. This was also the story I got from 3 shops that everything had to be dropped. Jim Bailey advises that the tranny can just be unbolted and slid back to release the TT. I haven't been under yet to have a look but Jim's approach sure seems like the way to go. What was your experience?
Old May 11, 2003 | 06:13 PM
Deb's Avatar
Deb
Post
Hi Karl, thanks for the heads up, I'll have a good look at the TT I get. I'm a little confused about this service and maybe your experience can shed some light. All of the info I get from the web and 3 shops talk about dropping everything but the ashtray to get the TT out. Jim Bailey -further back on this thread- suggests leaving everything in place and just sliding the tranny back to drop the TT - sure would be faster. What was your experience? Thanks
Old May 12, 2003 | 11:30 AM
Mark Anderson's Avatar
Mark Anderson
The Parts Whisperer
Post
I have personally done this job in a parking lot in just a couple of hours. As Jim said, the 5sp does not require trans removal. I did remove the exhaust and drop the clutch. I attempted to do it without removing the clutch but I found I was spending more time trying to avoid the clutch removal that the time it took to take it out.
Good Luck,
