GTS Mirror Assembly
GTS Mirror Assembly
All,
I am having problems in fitting the new GTS mirrors on the S4. I have been following the exploded diagram and am finding it very hard to compress the spring (7) into the housing (2) and then feeding the whole thing into (3) and twisting and locking with (6).
The sprong is so hard to compress that I cannot feed it through. Any ideas what I am doing wrong?
Nadine
Nadine
Electron Wrangler
From all accounts its just really hard to do - you need a lot of strength to compress it. Others have favorite methods and means to hold support it while attaching - but you may need to get some burly help...
Alan
Alan
Rest in Peace
Here is a link, it worked for me on the spring.
http://www.951motorsports.com/#Final...ors%20to%20Car
Rest in Peace
I ended up using that blue 3M plastic masking tape to hold it in place while I was installing the mirror.
But it is hard to get the gasket on the mirror base then to get the tape on it to hold good enough and not go under the gasket.
I just put a set together on Sunday, Either use the link posted above and compress the spring that way.
Or you can find someone to muscle them together for you. I would do it for you, except I'll need about a week to recover from mine. It was quite a workout!
