What repairs have you done this year?
My 928 wrenching this year has been mainly on the 84 and all of it maintenance related. I've worked on the weinrot a bit as well all get it back together related. The 78 just arrived and has already seen some attention.
On the daily driver 84:
Rebuilt axles; new boots on one side 6 months later
Fresh diff fluid
2 Mobil 1 oil and filter changes
fuel filter
Brake fluid flush
T-belt retention
clean misc. switches
cleaned speedo connector under tire
Wally's annual electrical maintenance list
5 new Bridgestone S-03's (killed one w/leaky stem)
still fussing with hatch release switch
Needs TC seals
Awesome beast of a car.
On the project 83:
F/R wheel bearings
new engine rebuild parts
engine trial assembly/disassembly X 2
misc cleaning, scrubbing, bead blasting, painting
Will someday be a great track car.
On the new-to-me 78:
6 gallons of gas
iso-propypl, fi cleaner
Mobil 1 oil/filter
New stock air filter
titened misc hose clamps, checked for leaks
complete vacuuming/wash/misc sticker removal
New brake pads, rotors, fluid (LF caliper enroute)
Scrubbed/cleaned phone-dials
cleaned window switches
Fresh tranny fluid enroute
New hood/hatch shocks enroute
New set of S-03's enroute
Can't wait to get this one on the road.
Fresh diff fluid
fuel filter
Brake fluid flush
T-belt retention
Needs TC seals
On the project 83:
F/R wheel bearings
6 gallons of gas
Mobil 1 oil/filter
timing belt replacement and retention (did the retension myself), hood struts. RMB, New front floor mats (the old ones were warn out so this qualifies as a "repair", these are black with red "928 GT" lettering and the look great), rear tires.
Bought a set of cast hole rotors, shoes, pads and sensors for the winter project.
I am still NUTS about this car, even after all these years......
Well ok where to start.
I bought my car in March of this year and went right to work on her.
- Replace pass. door panels
- Replace center consoul
- Repair heating controls ( nasty one ) The auto controls had been removed and old manual controls had been hacked in place
- Repair wirering and fusepanel
- Repair both power seats
- Remove tranny, TT and rear suspention to tap new threads in the bolt holes that hole said assembly to the car. It was missing 3 bolt all stripped (very scary)
Cry and scream when I find out Tranny is the wrong one for my car. (84 euro with a 79 us 3spd)
- Pull rear guater panels and wacth the crumble to dust under the leather.(more crying)
- Pull motor
- Disasemble motor find origonal water pump and 2 frozen bearings on idelers. Find water pump impeller has hit the block a few time ( its ok still thank god) Find broken stud on oil pump pully hanging on buy two threads(lots of praying and being very thanksfull at this point)
- Headers on the block but block still on engine stand
-New exhaust (no cats its a euro we dont want no stinking cats)
_ other then that a few small repairs to light and cluster like the od gear and all new lights
So as of today the trany is back in the car (Yes the wrong on) along with the TT. Motor is still on the stand waiting for me to make some money and buy the rest of the parts I need. I did get to drive the car this year. I went out with a local group to a dyno day where i put down measured numbers of 225.4HP@6000rpms and 242.2FT-LB tourqe at 4200rpms and to a import drag where i ran mid 15's on the 1/4 mile.
Thruston Pritchard.
<img src="graemlins/beerchug.gif" border="0" alt="[cheers]" />
- Pull motor
Thruston Pritchard.
I just looked at my list. Frightening!
'83 S Euro 5 sp.
Replaced old front seats with used ones.
New 3' exhaust system from headers back.
Rolled fender lip to accept bigger wheels/tires
Paid body shop to seal paint cracks from rolling fenders.
Added momo steering wheel.
shortened shifter lever.
Added momo shifter ****, broke factory rubber one.
Changed trans oil to swepco.
Bought new radio/CD player, not installed yet.
New floor mats.
Replaced aluminum ball joints w/steel ones.
New Bilstein shocks.
Added adjustable spring perches.
Raised ride height of car.
Repaired front spoiler and reattached properly.
alignment all around.
Replaced ignition lock and switch.
Replaced turnsignal, headlight dimmer switch.
New thermostadt and fan switch, not installed yet.
New 17" 3 pc wheels.
New Kuhmo tires, 255x40 and 275x40.
Ran on dyno, 262 rwhp/ 260 ftlb.
then...Passed Oregon emissions test. <img src="graemlins/jumper.gif" border="0" alt="[jumper]" />
Much still to come...like vacuum lines,(ordered) plug wires, fuel filters, coil, distrib cap & rotor, all synthetic fluids, new console and dash, carpets and on and on.
Happy New Year and thanks for all the help and advice this year.
JF
'83 S Euro 5 sp.
New floor mats.
JF
Purchased end of Aug, 2002
115K miles, 3 previous owners
Ran very rich; not that fast.
Fixes/changes in order of work done:
Voluntary emissions check* = HC way too high
+ All external light bulbs, <a href="http://boards.rennlist.com/upload/HID-Composite.jpg" target="_blank">fabbed hinged front license plate holder (folds back at +5 mph)</a>
+ Temp sensor, Temp2 sensor, Cold-Start switch, Air Flow Meter, Oxygen Sensor, Coil, Plug Wires, Silver Plugs
- PO resistor on temp sensor wiring
+ Fuel pump, fuel filter, fuel pressure regulators, fuel damper, injector seals, injector connectors
+ Throttle switches, all intake hoses/o-rings, intake isolators, all new braided vacuum hoses
+ Oil hoses, intake air ducts, washer fill tube, dimmer switch
+ Air dam, brake cooling ducts, jump-start **** cover, wiper bolt covers, side-marker gaskets
+ <a href="http://boards.rennlist.com/upload/HID-Composite.jpg" target="_blank">Fabbed Racer-X chicken wire front grill</a>, VDO gauge on fuel rail
Voluntary emissions check = passed!
- Spare, tools, jack, rear visors, foam under front carpet, disconnected factory alarm
- AC pump, condensor, engine driven fan, fan shroud, air pump, air pump hoses, AC idle speedup valve
+ 75 degree AC fan switch, oxygen sensor wire from computer grounded, set timing to 26 degrees, AFM mixture adjustment
+ Adjusted throttle cables, adjusted vacuum modulator, adjusted parking brake
- Crappy PO radio, remainder of factory radio, amp wiring, fader wiring, oxygen sensor clock, electric antenna
- Cruise transducer, cruise brain, seat belt warning relay, parcel shelf, oxygen sensor clock cover
+ Cleaned dash connectors, reglued rear view mirror base, fixed rear wiper
- Vacuum limiter, charcoal cannister, vacuum retard hose, venturi Y-connector
- Fender splash shields, sunroof motor and trans, side marker bulbs
+ <a href="http://boards.rennlist.com/upload/HID-Composite.jpg" target="_blank">8" H4's with Stronguards, real HID retrofit</a>, adjusted headlight mechanism
+ Adjusted dead pedal, accelerator pedal, <a href="http://boards.rennlist.com/upload/NewFuse.JPG" target="_blank">fabbed adapters for 25amp fuses to AFC circuit-breakers</a>
+ 4 245/45/16 Kumho 712's, <a href="http://forums.rennlist.com/forums/ultimatebb.php?ubb=get_topic&f=14&t=003724" target="_blank">air box straps</a>, shifter plate
- HID system (couldn't live without proper high-beam) <img src="graemlins/c.gif" border="0" alt="[ouch]" />
+ PIAA Superwhites, Porsche valve stem caps
- Cat, factory exhaust, rear muffler heat shield, bumperettes
+ Fabbed 3" single exhaust system, Flowmaster Delta 40, 2 3"x12" resonators, Monza twin tip resonator
+ <a href="http://boards.rennlist.com/upload/Silencer2.JPG" target="_blank">Fabbed exhaust silencers
</a>+ Fixed PO dent
- PCV hose to intake, front visors
+ <a href="http://boards.rennlist.com/upload/P1010004.JPG" target="_blank">Breather on oil cap</a>, set timing to 33 degree, AFM mixture adjustment
Weight now 3230 lbs with half tank; PDQ (pretty darn quick), max speed driven so far: 138mph. <img src="graemlins/burnout.gif" border="0" alt="[burnout]" />
*FYI: Negative emissions checks (even voluntary) show up on Carfax reports!
</a>+ Fixed PO dent
