928 Forum 1978-1995
Sponsored by: 928 Specialists
Rim Width And Offset???
Old Oct 31, 2002 | 04:08 PM
Bernie's Avatar
Bernie
Question Rim Width And Offset???
Quick question on rims.
I'm selling my 16" slot rims on ebay
and was asked what the width and the offset are?
The rims are slotted, flatdish of an '85.
Thanx in advance for the ifo folks.
Cheers
Old Oct 31, 2002 | 05:53 PM
SharkFan's Avatar
SharkFan
Talking
Hey Bernie,
You can goto <a href="http://www.928gt.com/" target="_blank">928 Specialist</a> and look under Tips/Links. This will give you a list of factory wheel and tire specs.
Good Luck,
<img src="graemlins/beerchug.gif" border="0" alt="[cheers]" />
<a href="http://www.p-caronline.com/directory/vegas_81'_928_euro/" target="_blank">MY P-CAR PROFILE</a>
Old Oct 31, 2002 | 06:13 PM
Ed Ruiz's Avatar
Ed Ruiz
Cool
If they're the OEM rims, the width is 7" and the offset is 62 or 63mm. BTW, it should be marked on the inside of each wheel. YMMV.
Old Oct 31, 2002 | 07:42 PM
BrianG's Avatar
BrianG
Question
Ed: I have a set of 16" phone-dials that I have an opportunity to mess with. I plan to widen them. If one splits the rim and separates the bead with a spacer, what would you calculate the max interference-free width will be, without moving the hub from its side? WOuld it be different front from back? <img src="confused.gif" border="0">
Old Oct 31, 2002 | 07:47 PM
Bernie's Avatar
Bernie
Post
Thanx for the help guys.
928 Specialists chart says 6x17 with 65mm offset.
See Ya
Old Nov 1, 2002 | 12:10 AM
Ed Ruiz's Avatar
Ed Ruiz
Post
Bernie: I think there is a typo. I doubt that your wheels are 6"x17". I would bet they are 7"x16".
Old Nov 1, 2002 | 12:13 AM
Ed Ruiz's Avatar
Ed Ruiz
Post
[quote]Originally posted by BrianG:
<strong>Ed: I have a set of 16" phone-dials that I have an opportunity to mess with. I plan to widen them. If one splits the rim and separates the bead with a spacer, what would you calculate the max interference-free width will be, without moving the hub from its side? WOuld it be different front from back? </strong><hr></blockquote>
I've never heard of anyone doing what you propose to the OEM one-piece wheels. If they are two or three piece wheels, then I stand corrected. Otherwise - I advise you not split them. A set of aftermarket wheels that are wider would probably be both safer and more cost effective. YMMV.
Old Nov 1, 2002 | 02:34 AM
BrianG's Avatar
BrianG
Post
There is a wheel shop here that insists that they can do this, and do it all the time. I saw their work and it looks sound.
Old Nov 1, 2002 | 02:42 AM
Bernie's Avatar
Bernie
Post
Thanx Ed,
The typo was mine and not 928 Specialists.
Cheers
