Upper Radiator Hose - do I have the correct part?
Hi all,
I'm in the middle of replacing the cooling system hoses on the gold '86.5 and ran into a snag with the upper radiator hose where it connects to the water manifold. The new hose will not go on due to a difference in the diameters of the hose and water manifold nipple.
The inner diameter of the new hose (928.106.238.08 by CRP Industries) is 1 3/4" at the water manifold end whereas the corresponding nipple on the water manifold housing is 2" in diameter (2 1/8" if you factor in the metal ring).
The old hose (#928.106.238.04 - original 20+ year old part) inner diameter at the water manifold end is 2". When I replaced the hoses on the green '86.5 last year, I didn't have this issue. I found the old hose from that car and it too was 2" in diameter on the water manifold end.
According to the PET, 928.106.238.08 is the correct part# for my model year.
Has anyone encountered this problem before?
If so, what was the resolution?
Thanks,
Adam
Thanks,
Adam
Basic Sponsor
Hi Adam,
The hose needs to be a tight fit. If you use some dishwasher liquid it slides on there very easily and is a perfect fit. I cannot compare it to a Porsche hose as I do not have one. I suspect that the diameters would be the same or similar. We need to compare new for new as an old hose will have taken a set of the diameter it slides over.
CRP & Elaplast are the 2 OE's I am aware of.
Roger
Roger
![](https://cdn.shopify.com/s/files/1/1694/8685/files/928sRus_rennlist.png?v=1621798567)
Does it have the "Do It Yourself" manual transmission, or the superior "Fully Equipped by Porsche" Automatic Transmission?
George Layton March 2014
928 Owners are ".....a secret sect of quietly assured Porsche pragmatists who in near anonymity appreciate the prodigious, easy going prowess of the 928."![thumbsup](https://rennlist.com/forums/graemlins/bigok.gif)
Basic Sponsor
Hi Adam,
Glad that worked, however I will order a Porsche hose to double check that the OEM hoses are the same.
Thanks for the heads up.
Best,
Roger
Best,
Roger
Team Owner
I have found that different distributors sell different hoses and also different thickness hoses .
I got 2 sets at the shop one from the dealer and one from one of the suppliers I went with the dealer hoses since they looked like original hoses and the original thickness .
The supplier parts were thinner walled and also bent slightly differently
