Porsche 928 Clutch Help!
I have purchased two new clutch discs and I am not sure which one is which. If anybody knows which one is the engine side or the transmission side please let me know.
Thanks a lot,
Shawn
Thanks a lot,
Shawn
Lucily I just disassembeled mine. If you compare the center sleeve of both disks (where the short splined shaft goes through) one disk should have a slightly longer sleeve than the other. The shorter sleeve disk goes closest to the engine with the sleeve protruding towards the rear of the car, the longer sleeve disk goes closest to the pressure plate/throwout bearing again with the sleeve protruding towards the rear of the car. Hope this helps!
