ABS Wiring Loom Query
There is no continuity between the LH Front ABS sensor connector and pins 4 & 6 on the ECU connector. The wires at pins 4 & 6 are Red (and those for the RH pins 21 & 11 are Green which makes sense), but the wires at the sensor connector are Brown/Black so there must be a connector junction somewhere.
Where is this connector junction? - Thanks
It appears I may have switched the ABS and Pad connectors when I repaired damage caused by a leaking coolant pressure sensor. The Brown/Black cables are in fact the Pad sensor cables. I'll be able to confirm this later today.
I now have working ABS for the first time since I bought the car six years ago. Very Satisfying!
Thanks to everyone for their posts in some of the other threads, in particular JFrahm.
