928 Forum 1978-1995
Sponsored by: 928 Specialists
cam sensor question
Old Mar 19, 2008 | 12:12 AM
BobS!'s Avatar
BobS!
Question cam sensor question
I was putting a new sprocket on the right side of the engine. There is a sensor of some sore right behind the sprocket. What is it? Yes I looked, I cannot find it in the manual. I car is a 1988.
Old Mar 19, 2008 | 12:31 AM
worf928's Avatar
worf928
Hall Sensor.
David L. Lutz's Avatar
David L. Lutz
Hall sensor. If not working properly it will retard your timing.
Check and be carefull with the connections, usually they are very brittle.
Old Mar 19, 2008 | 03:13 AM
Mrmerlin's Avatar
Mrmerlin
Team Owner
since your this far it might be a good time to install a new Hall,,, The connector housing for it and both of the knock sensors and the crank position sensor all seem to degrade and crumble at the same time
Old Mar 19, 2008 | 06:37 AM
Mike Frye's Avatar
Mike Frye
Craic Head
BTW- On a related question, you said you're doing the cam sprocket on the right side and found this. I'm sure you're actually replacing both sprockets, right?
Old Mar 19, 2008 | 11:02 AM
Vilhuer's Avatar
Vilhuer
Is sensor still available from somewhere? IIRR its not.
Old Mar 19, 2008 | 11:23 AM
ROG100's Avatar
ROG100
Basic Sponsor
Erkka,
I have a few in stock 8>)
Roger
