Power Bleeder: One man job on the 928?
Hey guys,
Forgive the simple nature of this question, but do you guys know if bleeding the brakes & clutch can be done by one person with a Power Bleeder?
I just bought one and have never used one, but it seems like once you build up the pressure, that it should be a one man operation.
Any input on that would be appreciated.
Thanks!
Ed
ps: going out to the garage shortly to do some work on the S4. Holy cow, its been a long time since I even touched it - poor car.
Thanks!
Ed
Hey guys,
The power bleeder is a great way to check for leaks too. Once the job is done, leave it on, pump it up to 10-14 psi and leave it for 15 minutes to make sure the pressure doesn't drop.
Matt
Great tool for one-man operation, just be sure to either put a lot of fluid in the bottle to begin with, or keep popping back between wheels to check that there's plenty of fluid left so you don't get air back in the system!
Mine's an auto S4 so can only speak for the power bleeder for brakes - it's a fantastic tool and does an excellent job. A big part of its appeal is it makes bleeding a one-man job.
I got the Motive from 928SP and it's great, have already bled the brakes and clutch multiple times, getting ready to again because I'm replacing the clutch master and slave. Real one-man operation, very easy to do. 12psi is plenty of pressure and works just great. I used to use speedbleeders and this is MUCH easier.
I have been hoping for some positive responses to the Motive power bleeder. I did a search on these yesterday (I am considering the Specialists deal), I saw alot of guys on the list are not fans. Guys that seem pretty handy have had some trouble using it, and have gone the speed bleeder route.
Maybe I missed it skimming the posts above... do not go above 10psi unless your clutch 'blue hose' is clamped at both ends. It WILL pop off and make a mess if you run the pressure too high. With it clamped (use injector clamps to protect the hose) you can go over 20psi with a healthy system.
I used a power bleeder for a while, now it just sits in the garage. I just 1-man bleed without it now (usually without lifting with the wheels on). If I had a major issue, I'd go back to the power bleeder.
one man job, no more than 10 psi as discussed previously.
one can of super blue brake fluid in the power bleeder tank
pump it up to 10 psi
bleed farthest brake first (right rear), then work forward (left rear, right front, left front)
when bleeding clutch, open bleeder on slave cylinder, and pump clutch pedal vigorously to get all air out--otherwise, you'll have air in the clutch master cylinder.
flush each bleeder until new fluid comes out, don't just bleed to get air out if you have no clue as to when a total flush was last done.
good luck-
--Russ
good luck-
--Russ
