928 Forum 1978-1995
Sponsored by: 928 Specialists
Help with Central Indicator Unit?
Old Mar 9, 2008 | 09:27 PM
robot808's Avatar
robot808
Default Help with Central Indicator Unit?
Does anyone have a picture of the back of the Central Indicator Panel for an OB? I mean the unit in the console with the acknowledgement button.
I think some wires broke off of the unit for my 82 5 speed. I think I need solder them back on, but want to be sure of the placement.
Thanks to all.
Old Mar 10, 2008 | 02:53 AM
robot808's Avatar
robot808
Default BUMP
I am really close to finishing a job that would get me back on the road after a long layoff. This is basically the last thing I have to do. Please help.
Old Mar 10, 2008 | 09:25 AM
Leon Speed's Avatar
Leon Speed
This one?
https://rennlist.com/forums/showthre...entral+warning
Old Mar 10, 2008 | 06:28 PM
robot808's Avatar
robot808
Thanks Aryan,
That is just the kind of pic I was hoping for, but the 82 has only 6 wires I am aware of. 2 of which are still connected. I can't seem to make it out on the wiring diagram either. There is a 4 pole connector that goes to four posts on the unit. This is my best guess for those:
1=brown
2=red
3=blue
4=gray
There is also (I believe) a two pole connector that has a a black wire and a white wire that (I believe) lead to two poles labeled (appropriately) 1 & 2.
Now, with that connection I have about a 50/50 shot, but I was hoping someone could give me a little edge on the odds.
Thanks again for any help.
Old Mar 14, 2008 | 06:11 PM
Alan's Avatar
Alan
Electron Wrangler
Bob - figure it out by function:
Red & Blue should go to the bulb behind the reset switch - it will measure probably about 10-20 ohms when the bulb filament is cold. The orientation doesnt really matter.
The Brown & Grey go to the switch (its a momentary connection press switch) again the order doesn't really matter on these - closed circuit when pressed.
The Black & White go to the seat belt warning - two bulbs in parallel behind the logo panel - approx 5-10 ohms cold on these.
Once you figure out the connections you can apply 12v across the bulb connections to illuminate them and verify you have the right ones..
Alan
Old Mar 14, 2008 | 07:58 PM
robot808's Avatar
robot808
Got it, thanks Alan!
