928 Forum 1978-1995
Sponsored by: 928 Specialists
dropping auto tranny
Old Jun 28, 2002 | 09:05 PM
928 U.K.'s Avatar
928 U.K.
Post dropping auto tranny
after being away for a while i am going to start to drop my tranny at home and put it in for reconditioning as i have been quoted £650 for the rebuild and twice that for removal and installation i was wondering if anyone had any tips before i get started this weekend i have no worries about the timescale but as usual i am working to a limited budget. i will be posting the steps i take on the board as i go as a reference guide "hopefully" for others
questions
how high to get the car up?
advice on dropping the suspension?
any special tools i need to buy or hire?
many thanks
Tim 84 s2 euro auto(i wish)
Old Jun 28, 2002 | 09:57 PM
Mike Schmidt's Avatar
Mike Schmidt
Post
The following link might be of some help.
<a href="http://members.rennlist.com/v1uhoh/torque.htm" target="_blank">http://members.rennlist.com/v1uhoh/torque.htm</a>
Old Jun 29, 2002 | 06:13 AM
928 U.K.'s Avatar
928 U.K.
Post
Mike
thanks for the link looked at it briefly and it looks very informative i am going to study it now and maybe use it as a guide
Tim 82 s2 auto euro
Old Jun 29, 2002 | 07:48 PM
Tony's Avatar
Tony
Wink
just dont hold me liable !! : )
Tranny drop isnt thaaaaat bad really. Just an awkward weight to handle. Get your self an extra floor jack to help you out. I found the height i had my car was just right. Too high and its hard to get the tranny down by yourself, too low and it just doesnt come out!
The engine will have to be tilted slightly as there isnt enough clearnce at the **** end of the tranny to clear the battery box when you slide it off the torque tube...which leads to another subject, may as well replace that as well if it is making any noise. its dirty, frustrating, and not the easist job but it can be done at home! <img src="graemlins/beerchug.gif" border="0" alt="[cheers]" />
Old Jun 30, 2002 | 06:56 AM
928 U.K.'s Avatar
928 U.K.
Post
thanks Tony
i have got the car up on axel stands front and rear
taken off exhaust and heat shields
studied what needs to come off the box i.e wires cables tubes
sprayed al the bolts with w.d.40
loosed half shaft bolts
next stage is to lower the suspension which looks like a big job any advice on this subject would be a great help
thanks for the posts Tony and Mike
Tim 84 s2 euro auto(put 82 in previous post which was wrong)
Old Jun 30, 2002 | 03:19 PM
Tony's Avatar
Tony
Post
I would make sure you have the jack stands well set up. It will take some good tugging on the tranny to pull it off! You dont want the car rocking and swaying above your head!
When you remove the bolts from the tranny/suspension lay them in a pattern so you knwo where the go back in....when you can reinstall them partially after the susepension and tranny are out. If i recall some are different lengths etc etc. It will just make it easier when you put it all back to gether. Also take a wire brush to the threads to clean them up. Odds are you will get a lot of dirt and crud stuck to them when they come out.
Old Jul 2, 2002 | 06:30 PM
928 U.K.'s Avatar
928 U.K.
Post
Thanks Tony
i have got the car up on wooden blocks front and rear and axle stands front and rear
i thought that i would spray paint the bolts and where they come from different colours so that i know where they go
