Widening wheels?
Administrator - "Tyson"
Unless you are really hooked on original phonies, I see little reason to modify a modern 18" wheel with so many custom options available.
I think they still make the Goodyear "Bollboard" tires popular with the Cobra crowd.
I read about a "group buy" the Pantera / Lamborghini group put together years ago to persuade Perelli to make a batch of super wide tires for their cars.
![](http://www.erik27.com/79928/images/DSC_3459.jpg)
About the only option for a wide rear (that I've found) is the Hoosier A6/R6 race tire. Available in 255 & 275 @ 16"
Hoosier also makes a 255/50R16 radial wet tire. At $240 each I would really have to be in love with phone dials to go that route.
That's a lot of work & money to only have a 255 on the back.
Here's a company that widens wheels:
http://www.weldcraftwheels.com/index-1.html
No experience with them personally.
We only did it on the Camaro because he likes the Halibrands that are on it. For something that you can already buy in the correct size it makes no sense. That, and you start to border on what custom wheels cost so that gets to be an attractive alternative. I wouldn't have done it, but it's not my car. I'd have bought Fikses.
The reason I bought the thread back instead of a new one was so we don't get a gad zillion threads on the same topic. I thought that is what we were supposed to do?
Back to the question at hand and why, the reason of why to use the genuine wheel is that I like it and I wanted to keep that look. The weight for the front is reasonable at 23 pounds for the 10" and around 25 for the 11" rear. They are a simple design that is also easy to clean which helps too.
The front would end up with 82 mm offset which I think should be good and with some work to the inner and outer guard the offset of 51 mm on the 11" rear should work out also. By the time I turn 6 wheels into 4, my cost will be a bit over $2K then add the cost of welding and painting. So my guess was $3K with some paint.
Unless I import them especially, there is nothing custom available and the magnesia wheel that is made for Porsches didn't have the right offsets. They were $5K a set. How much are nice set of custom wheels out of the States? Just remember that anybody importing probably has to add another $1K for freight and customs. BBS wanted $6K btw.
For the engineering types do you think the rim should be re-heat treated? I would definitely want the weld on the outside machined down. I would have thought they would need to put the rim back in the lathe to make sure it was true. Thanks in advance.
Do any of those nice lightweight wheels in your GRM ads fit Porsches?
I had my phone dials widened to 9.5 rears and use a 1.5" spacer.
I too am thinking that 16" tires are going to kill my use of the Phone Dials. When it is time for new tires I will probably buy 17 oor 18" wheels.
Look at the gold with the 9.5" PD
Silver with 9.0" Twist
Black with 8" Manhole covers.
