Upper Control Arm Bushings??
7th Gear
![Angry](https://rennlist.com/forums/images/icons/icon8.gif)
My upper control arm bushings are significantly distorted. It is enough to displace the upper ball joint by nearly 5/8 inch. The ball joint, boot, and arm are all fine. Excluding the bushings, it is dimensionally identical to the other side, and shows no signs of any damage.
I have tried to find a source for these bushings, but to no avail. I understand that they are not available individually.
Any suggestions????
Any suggestions????
Vince:
I have a complete set of upper control arms from my 85 that will fit your vehicle. I changed these out this spring when I did a
brake upgrade.
If you can't find the bushings I'll make you a deal and get them out of my garage.
Regards,
Ken Bigham
Celina Ohio
brake upgrade.
Regards,
Ken Bigham
Celina Ohio
